What is the best glue for light colored wood?
Leo Cuellar
Leo Cuellar
Which type of glue leaves the least noticeable line? I've been playing around with the bowl from a board thing. I have some nicely colored & figured maple I want to use for this, but so far the 3 types(2PU & CA) of Gorilla glue I've got on hand look bad. I could really use a few suggestions before I shell out more money.
This is one of the tests out of the plainer stuff.
Re: What is the best glue for light colored wood?
Malcolm Tibbetts
Leo, my glue choice would be Titebond Original. Assembling light colored to light colored requires perfect joinery; don't forget to blow the surfaces clean.
fgvanatta
Here are some light-colored (birch) BFAB's assembled using TiteBond. All 3 were made from a single block of birch like the one shown.
I'm Thinking" Its not the glue.
My guess is your stock (wood) has oxidized or "photo"...whatever wood does when it ages and darkens. I think you have a very thin layer of discolored wood on the surface and that's what is showing up in the joint. Try planing or sanding a 1/32" off each side of your next piece and glue up another.
And, I would use Titebond Original.
Leo Cuellar
Thank You!:)
Leo Cuellar
Thank you for the suggestions. I will get some Titebond tonight after work. I wondered about the "aging" of the surface as well. I will also re-plane the surfaces the next time I try this.
Leo Cuellar
Leo Cuellar
Your birch bowls look nice. I've got a 100 bf of 5/4 that will get planed up soon for Arts & Crafts shelving for some of my books. Now I know what to do with any leftovers.
Leo Cuellar
Re: I'm Thinking" Its not the glue.
Leo Cuellar
Thank you again Barry. You were right on the money. It was the aging that was the most important factor, whether mine or board's was the most detrimental, remains to be seen :D
Gorilla on the left, Titebond on the right. Same tree, clean board. Flubbed the first TB lamination, didn't notice that my top ring had slipped off center. Took a couple of days before I had another chance to try. Much better results this time around!
Very nice....
Much Better. Now that you have that solved and can make practically invisible joints, You need to try some of the things John is working on and celebrate them.
Leo Cuellar
Re: Very nice....
Leo Cuellar
Yes, he comes up with some really cool stuff! Especially his latest post on BFAB. I've got a couple of double reverse shapes I want to try, and will play around with some coloring as well.
