working on trying to take better pictures
Tim Aley
New to posting my work, trying to upgrade my photography skills.
All comments welcome. Oak bowl 10 x 3 ...
Re: working on trying to take better pictures
I does look pretty good. There are still some problems. It appears a little yellow on my computer. What type of lights are you using? If they are tungsten lights try to set your camera to the Tungsten white balance setting.
You do have one light brighter than the other one which is good. Try changing the postion of the lights so they don't come off as headlights when you do see the reflection. Move the bright one up and maybe slightly to the back a little. The try moving the other one more forward and down. They don't always have to be 45 degrees to either side.
The sharpness and focus are pretty good which is them most important thing. Good job.
Tim Aley
Thanks John!
Rob Wallace
Rob Wallace
Nice turning Tim! Good form to accentuate the figure of the wood.
For my taste, I would like to see fewer distractions of the cloth folds, etc. in the background. I use a gray to black gradient to shoot against, and it focuses the attention onto the subject. I agree with John that there's a color balance issue that likely can be solved with software settings on the camera. Photoshop will let you also make similar color corrections, but it's a bit more of a hassle. Try to get the best primary image you can and don't rely on post photography software to correct any image's deficiencies. Practice a lot and don't be afraid to bracket and adjust lighting and exposure parameters. CCD electrons are really cheap compared to film, so shoot a lot and then high-grade the images that look best (.....deleting suboptimal images is free too!).
Cheers,
Rob
Don at Central Illinois
Like Rob, I bracket a lot. I may have 8 - 10 photos to choose from before I ever go into post production in Photoshop. As they used to before digital, film is the cheapest part of photography.
It appears you are using direct .....
JamieDonaldson
...rather than a diffused lighting set-up, and you would benefit from reading the Phrugal Photo tutorial posted here on WC or on my website at jamiedonaldsonwoodturner.com under the tips menu. The cluttered foreground and background draw attention away from the subject, and a white vinyl window shade makes a nice setting/sweep for most turnings, and the price is right.
Re: It appears you are using direct .....
Tim Aley
Thanks for all the help!
