Large skew chisel suppliers? (More than 1 1/4")
I have a 1 1/4" skew. I am happy with it. I was wondering if anybody knew of any suppliers of something a bit larger? I wouldn't mind having a 1 1/2" or a 1 3/4".
I would prefer an oval skew.
TIA.
TIA.
Re: Large skew chisel suppliers? (More than 1 1/4"
Jorge Casta�eda
Jerome,
I have a couple of oldie but goodie that I use seldom, I would not mind parting with one, I think they are 1 1/2" or bigger, need ti dig them out.
I'll send you a picture later today. You could send me some wood if you like it.
Jorge
Just out of curiosity
wilbur
Why do you want a larger skew? I have a 1-1/4" skew, and love it, but I'm having trouble figuring out why an even wider one would be of benefit.
Jorge Casta�eda
Jerome, there is only one left, a 1 3/4" Whiterby, a respected name from Connecticut.
The blade is about 5" long and the tang is 4", no handle.
Re: Large skew chisel suppliers? (More than 1 1/4" *LINK*
JL Modify one of the Sorby Framing Chisels you can get from Lee Valley. I picked up a damaged framing chisel that was about 2 1/2" wide, 3/8" thick. I reshaped the edge to a skew and use it occasionally. So far I haven't found anything I do with it that I can't do with my Thompson skew.
http://www.leevalley.com/US/wood/page.aspx?cat=1,41504,41529,30012&p=30012
My 1 1/2 " Skew
Gil Jones
I bought a new, Benjamin's Best 1 1/2" round nose scraper for $23 (they are now $29.95).
The HSS is very nearly 1/2" thick, fairly OK quality for the price.
http://www.pennstateind.com/store/LX130.html
I cut the front angle with a die grinder and thin disk, and then proceeded to form the skew cutting edges on an old grinder.
It works very well, and was not costly. The steel could be of better quality, but then the cost would rise.
Gil
Re: Just out of curiosity
wilbur, when I rough smaller diameter spindles, I often use my skew chisel. It leaves me a cleaner surface than a roughing gouge. If you are doing larger pieces - like chair legs or table legs - it would be nice to have a wider "sweet" spot on the chisel to cut wood faster.
That's why I'm considering a larger skew.
JL I rough with the rough out gouge and then use the wings which I keep straight as a skew to make the last pass or two. I have a left hand and right hand skew when I do it this way.
It gives me a spindle that only takes a light pass or two with the skew. Keeps my skew sharp so I don't dull it as fast. It's much faster to sharpen my rough out gouge.
I figure it takes the same about of time to sharpen my skew as it does my roughing gouge. I just get my hands wet when I sharpen my skew
Seriously though, I have established my bevel on my skew - it just takes a couple of "strokes" on my water stones. I usually just do 1000 grit and 4000 grit. I guess it is really "honing" and not sharpening.
