Here are my latest bowls. The first is Red Oak with Padauk inlays. I'll have more on how I did this later, I've got to run a shoot students moving into the dorms followed by Womens basketball headshots, action etc.
The second one is a Walnut bowl with Red Epoxy. This is the save from making the wrong parting tool cut. I think I did pretty good on this save.
Yea I know I should have use more depth of field but I was in a mad rush to shoot these. Students are back so my free time is all but gone.
Actually John, the second piece is far more than a "save"; I am wondering now how to TRY to do this - I think the effect is really neat, particularly with the translucent nature of the epoxy. Can you tell us in a bit more detail how you actually did this?
This example further illustrates how "mistakes" are really better defined as "new design opportunities"!
Rob The first time I had seen this done was on a goblet. It was at an AAW symposium. I don't know who did it but it made a very strong impression on me. If you want to do something similar just make a parting cut and fill it with epoxy.
The way I did it was to create a Dam out of masking tape to contain the epoxy. When I mix the epoxy I use acrylic paint to color it. I actually used too much in this case because it wasn't as transparent as I would have liked. The epoxy I use is West System and it's very thin so I can simply pour it in out of a cup. Let it harden and then turn it away. Then I just turn the wood thin enough to cut into the epoxy on both sides. The more transparent you make the epoxy the thicker you can leave the wood.
If you don't want the epoxy to be transparent you can mix in thickener with it and fill the gap without making the masking tape Dam.
