English Walnut Platter
Barb Siddiqui
First picture is to show the results of truing the face of a 12"d. wany piece of English walnut. It started out just under 1" thick.
The dot near the center is not my center hole, but a *#%&!* pin knot that revealed itself in flattening the front. It is 'just' off center, and drove my eyeballs crazy looking at it, so I decided to drill out a wide hole to seat a glass bauble, domed on top and flat on the bottom.
Final dimension is 11-1/2"d. and approximately 3/8" thick. I had read that one is supposed to 'dish' the bottom slightly so it won't rock on a table, so I tried, but the wood was so thin, I don't know if I succeeded in doing it correctly. It doesn't rock, so I must have. The pin knot is still visible on the back side.
Comments very welcome. If you see something I should have done differently, help me learn. I know I want to start with thicker wood next time. This was an experiment, but 7/8" is too thin for me to have any wiggle room for designing a dish. I'm unhappy with the edge treatment here, too. Se la vie.
