vid of The Youngest Sister piece - in action *LINK*
charlie belden
Put together a video of The Youngest Sister piece - one of three pieces in The Three Sisters set. Two done, one to go - The Oldest Sister. Am still working on a set of web pages about these pieces and how to use a micro-computer / stamp controller to add light, sound and movement to turnings. It's been a bit trickier than I initially thought it would be but I hope the stuff I put together about it flattens the learning curve a bit for some other turner.
Comments, questions and constructive criticism welcomed.
Please keep in mind that these are very early attempts at adding some new dimensions to turning and merely hint at what might be done. Refinement and elegance will come in time - I hope. Please also excuse the video quality - it was semi-thrown together to illustrate an idea,
YouTube vid of The Youngest Sister piece
Re: vid of The Youngest Sister piece - in action *LINK*
Steven Antonucci
8 years ago, I would have used the light
steven antonucci
to make the coolest turned magic wands!
Neat piece. can you run it on a smaller watch battery? Set everything into the lid?
S
Re: 8 years ago, I would have used the light
charlie belden
There is a version of the Arduino - the Pro Mini- that would fit in the lid and could be run on watch batteries. But you still have to run wires from things TO the Arduino. For a set up that doens't require anything passing THROUGH the walls of the piece - the wires can be short and compact. But if a part has to be fixed to the piece AND the Arduino - wires have to be longer. And if you use fiber optic cables or clear acrylic rods to get light from one LED to multiple locations that takes some space too.
This first set of micro-computer controlled pieces are prototypes for what may come - identifying issues of using these things with turnings. With more experience with them, problems will get solved and new uses will pop up. Haven't gotten to MOVEMENT yet. Servos will no doubt present new challenges.
I have two Boarduinos - same functionality as the Arduino but in a smaller form factor. With 9 V battery, it's 3" x 3/4" x 1 1/2" - small enough to fit INSIDE a piece - with no wires sticking out of the bottom. Because the battery life is not infinite - having an On/Off switch has to be added to the system.
To go smaller, there's the Mini and Mini Pro that are about 1 1/2" square and with watch batteries - maybe 3/4" thick. But like bikinis, the less there is, the more expensive it is - around $35-$40 USD vs $17 for the Boarduino. Peter Rand is playing with these - working out ways to use them in some of his pieces.
Will be interesting to see where the use of micro-controllers goes.
