Next work on the lateh progress(big Jim)
Terry Scott
Our main competition in New Zealand The Kawerau wood skills festival
http://www.naw.org.nz/galleries/kawerau%202009/index.html
http://www.naw.org.nz/galleries/kawerau%202008/index.html
Is on again and I have to have my entries ready by Thursday .
Usually I am more organized but things woodturning wise have been very busy so I will be making a last rush as soon as I have tea and post this i am out to do some more
Having to send off the entry form 8 weeks ago makes it even more of a challenge as you have to name the work ,timber type and price the work (everything has to be for sale ) As you well know not every piece is a gallery exhibition piece
One section /category is Traditional woodturning with no more than 10% of the surface area decorated or textured
The competition just gets tougher each year so I thought id give this little burl a shot
Here is the process so far
The process is self explanatory
The Chisel is to show the scale I can swing 2.1m on my small lathe as you can see only a bit of clearance to turn the extended overlapping bowls.Sorry forgot to take a pic of the other end but I guess you get the idea
I had a few emails of doubt in regards to cutting a spiral(like thats not possible )
here I did this one in this punky burl ,just 2 cuts start from the center and with the chisel on its side pull ,I am using the bottom cutting edge like a drill bit
I guess this work may create a stir but I assure you I think these out for weeks before starting
The one below from the same wood is about the same size
Well have fun digesting this lot feel free to ask questions but I am off into the shop
I want to turn two spheres to sit in the dish at each end
Re: Next work on the lateh progress(big Jim)
Ronny Eelen
Terry, you are inspiring a lot of us, I think.
The work looks great.
And the series of pictures could/should inspire others to provide work in progress photos. It seems to say so much more when we get to see more than just the end product.
keep up the great works,
Ronny
Bill Blasic
Bill Blasic
Terry,
Awesome work! I'm sure there are winners pictured there.
Bill
Re: Next work on the late progress(big Jim)
Truly Awsome. Awsome in the sense of being huge and in the sense of being awe inspiring in the quality of the work. The wood ain't bad either. I am amazed. Thanks for posting.
A couple of questions. Are those straps the only thing holding the work to the face plate? I see them as truly scary. It seems to me they would hold just long enough for the lathe to get up to speed and then it would come loose and flog me to death. They don't even look like they would give you time to run away fast.
Jorge Casta�eda
Terry,
Your posts are always an eye and mind opener. Many thanks
Jorge
Bill Neddow
Beautiful piece, Terry. It has GOT to be a winner!
Steven Antonucci
Looks like fun
steven antonucci
A friend of mine gave me a burl cap like this, but smaller... I may just have to try this...
S
Don't know if I have what it takes
Mike Foster
to do work like this. It just looks a bit of a white knuckle trip for my taste. I've done a little off-center work, but it is nothing compared to what you do. Great work and cool to see how you do it.
Mike
Re: Looks like fun
Terry Scott
Happy to run you through the process if you need any help Steve cheers
Whatever It Takes
charlie belden
Damn! Terry, one of the many things I admire about you and your turning is your willingness to do whatever it takes to get an idea into reality. And if that wouldn't be enough - you then take the HOW - refine it - and use it for doing other pieces, each more refined than its predecessor.
WHEN DO YOU FIND TIME TO SLEEP?
Steve Kubien
People, people, do you realize....
Steve Kubien
...that the Krazy Kiwi is turning stuff too big for his Stubby lathe?!?!?!?! Nutter. Brilliant but still a nutter.
Ya know I love ya, right Terry?
Re: People, people, do you realize....
Terry Scott
That made me laugh Steve
If the maker of my old lathe could see the things I do on it know hed curl in his grave
Just as well I havnt got anything bigger ah
I had my Stubby custom built so it Swings 4 inches more than normal
The problem with the old Tanner it has the variable speed is on the head stock so I tie the lead to my leg if I have to get out fast the lathe turns off l.o.l
Phil Powell
Terry,
When do you eat or sleep? It seems that every time I sign on here at WC
you've been here first with something new and damn nice. Just guess I'll
need to give up my bed time if I'm going to catch up. You amaze me!
Phil
Steve Kubien
Steve Kubien
Is your Stubby a 1000 or a 750?
Re: People, people, a 1000
Terry Scott
A 1000 but you could say its a 1100 as I had the rail dropped at manufacture by 4 inches
Also had a few other modernizations made to my specs
The base plate and wall thickeness was increased from 10 to 12 mm
I had the index brought to the front as this is one failing they have as you had to reach over the head stock
The quill in the tail stock was a special but I have forgotten what I had done
The bed has a swing away bed
I beleive they have know been changed due to my insistence the variable speed control is know in all flexible switch boxes Mine is still on the machine only the on off switch is in the flexible mounting
This lathe has been a faithful servant ,no problems in 6 years apart from I was getting voltage drop under load causing the motor to cut out not the lathes fault as I was just running off a standard switch socket Once I ran direct from the board a 20 amp dedicated line all was fixed.
Just for fun I got a price for a new one a month ago but as our Paso is down against the Australian turned out to be very expensive about $12000 Nz with taxes all up delivered
As there are only three of these in Nz and the abundance of Teknatool lathes Id struggle to get 3k for my old one
plus anyone looking at buying it knowing I was the owner maybe put off l.o.l
Cheers
