Unconscious Behavior
charlie belden
No, this isn't about your behavior AFTER you've knocked yourself out with a flying piece of wood, nor about how you behave after you've had more than a few too many drinks - but haven't yet passed out. It IS about things we do without consciously thinking about them.
Case in Point
I usually turn "bare faced" - no face shield, no dust mask - nothing between my eyes and the wood - but my polycarb glasses - which I need - to SEE. I know - that's DUMB - but I'm a guy so I assume I'm indestructible - and NEVER make mistakes ; )
A nasty bout of bronchittis, probably brought on by some sanding without a mask or dust collector, got me shopping for a dust mask'/face shield combo. The AIRSTREAM - with all that's needed to actually use it - was just a wee bit pricey - over a grand when you add up all the parts necessary. Decided on the TREND AirShield Pro.
The first time I used it I felt like a cross between Darth Vader and an NFL lineman - once again indestructible - at least when it came to my head and lungs.
After turning with it on for a while I noticed that I could see where the edge was cutting better. I was concerned that the face shield would distort things so I was looking for that. Wasn't a problem at all.
I was using very familiar tools and making very familiar cuts - but I could see the tool and the cut being made much more clearly. As a result, the cuts were easier to make. Hmmm . . .
Took the thing off, turned some, paying attention to the cut. Things weren't quite as clear. Put the thing back on - I could see the cut better.
Thought about it a bit and came to the realization that, without the thing on, I'd been squinting as I turned, an unconscious thing humans do in glaring light - or in a dusty environment - to protect the eyes. With the thing on I'd stopped squinting and, with eyes wide open, could see better - an unexpected consequence of using the face shield.
I also noticed that, rather than holding my breath when I had to get my face closer to the piece while doing fine delicate cuts, I was breathing more normally - and thus was more relaxed. I'd still occasionally be biting my lip a little while making critical cuts - some old habits just don't go away - no matter what.
With turning, so much is often Muscle Memory and automatic - for this cut I do THIS and then I do THIS and . . .(sometimes it's "And now I go find a bandaid - after I get the bleeding under control.") - all done without consciously thinking about it. The mind is focused on DON'T SCREW UP, DON'T SCREW UP.
Doing Without Thinking can be a Zen thing - a Go With The Flow thing - a good thing. You get In The Groove - and things just happen. But SOMETIMES - if you pay just a bit more attention - you may find a better way, an easier way. And sometimes, just maybe, paying close attention while doing something very familiar - can lead to pieces you may not otherewise have done.
Has something inadvertently cause you to change how you turn - for the better? Care to share an insight or two?
