More bowl from a board
bilnpnky
Here are 2 bowls & a vase turned from boards of plywood.
The bowls were made from a flat board of glued up segments of plywood. One bowl has 4 segments (a square), the other has 6 (a hexagon) with inserts between the segments to give the basket weave effect. The rings were cut out of the board with a bandsaw as two pieces & then glued together & stacked.
The vase was made from a 1"x2"x4 foot board as an entry to a club contest to make anything from that size board. Plywood again was used with the layers running the length of the board. The plywood was cut into smaller strips on a table saw with 45 degree ends to form hollow squares that were stacked. (The top has one stack that is a hexagon). Some stack layers were rounds of plywood, these layers are in the horizontal plane.
One comment, as anyone who has turned plywood knows, it is a difficult material. The glue is tough on tools & the soft wood tends to tear out. The only redeeming value is the interesting patterns that result. Some people have asked how the wood was "bent" to make those patterns
Bill K in AZ
Re: More bowl from a board
Excellent work.  I love the first one.
Very cool effect.
Toney Robertson
What is the dark wood that makes the rim?
The first looks very thin, what is the thickness?
Like I said, very cool.
charlie belden
Very creative. With most segmented turnings, it's the color contrasts that are exploited. Here you've used the growth rings to create the patterns - revealing yet another wonderful characteristic of wood.
Visualizing outcomes from starting conditions is tricky enough when starting with a solid piece of a tree. Trickier when the starting conditions are pieces of different colored woods. What you're doing takes the "tricky" up several notches.
Really interesting idea.
First one is really cool...... nice work!
Ruth Niles
Re: Very cool effect.
bilnpnky
Toney,
The dark wood in the rim & base is walnut.
Thickness about 3/16" and diameter about 8"
Bill
Guy Bratt
Great work Bill. You do have an elaborate story about how you carefully bend each individual piece. Right?
Bill Kram
Right, Guy, the answer is to bend them carefully, like porcupines making love.
Bill K
