More bowl from a board
Guy Bratt
Well I tried cutting my bowl but I tried cutting my rings so they'd come off away from the headstock so I wouldn't have to stop and remove rings.
These are my observations
1. The ring comes off in your direction better be ready and stop before cut through.
2. I put my board on a glue block which when done cutting rings is inside my bowl. With the rings attached I can't reach it.
3. When gluing rings mark which side glues to which. &$#&*)&^%# :\
But for the first time it's not so bad so far.
Re: More bowl from a board
Guy Here's what I learned in the last few days.
If you cut the rings so they fall on the outside, wear a glove. I have 3 cuts on my fingers from not doing that. I tried cutting until it just barely came through on the backside, then taking a razor knife and cutting the final part. That didn't work so I just cut the rest with the parting tool. I find a diamond parting tool works well.
I use CA glue with accelorator to glue the bowl blank to the wasteblock. Then when I'm finished parting I can simply put a chisel in the joint and hit the chisel hard. It breaks away easily. I forgot to mention. I cut a very short tenon on the small side of the last piece. This makes it easy to align and glue into the new wasteblock that will hole everything for the final turning.
Put big pencil lines on the bowl blank before parting. This not only tells you what side to glue up but helps align the rings when gluing, if aligning is what you want.
2 more tips
My bowls are somewhat thin and bottom is pretty small. This leads to a lot of chatter and makes turning slow and frustrating. I made a large flat plate that I put on the face of the vessel. I push the tailstock against this. No glue, everything is just pressure. This steadies it up for turning the outside. If your not super confident how thick the inside is you can stop and pull it away and check.
Then the same thing is true with the outside. So I cut 4 pieces to fit the outside shape. I hot glued them to the outside. Next time I'll put finish on the outside first to the glue will be easier to remove, duh. To get the pieces off I used an old E string from guitar. I attached 2 handles and sort of sawed down through the glue joint. Then I used alcohol to clean up the remaining glue.
This made the turning go a whole lot easier. No chatter. Which was good on this bowl because the wood was kind of punky and it fought me. It got so thin you can push on the bowl about an inch down and it will flex. Once I got rid of the bad places it was a little less than 1/8" there. I decided to taper from that point on to about 3/16 at the bottom. This was quite easy thank to the GAugeT I got from Keith.
Re: 2 more tips
Guy Bratt
Some very helpfull tips John thanks. That first ring that came off was a shocker thought I broke it. Thanks again
Re: 2 more tips
Mine too. When they come off on the headstock side the chuck makes them spin and I was surprised that I didn't actually break a ring. They don't spin as much when they come off on the tailstock side but do come free pretty quick. I now turn the lathe speed way down for the last cut but even at 200 or so rpm they come off spinning pretty fast.
All in all I think the bandsaw method is certainly safer. However if your design would be ruined by a glue joint then the parting tool method is better.
