Non-Contact Interactive Dynamic Piece *LINK*
charlie belden
This is one of three pieces in The Three Sisters set I've been working on - for what seems like FOREVER. Like the other two, it uses a small, battery powered, programmable micro-computer to control its "behavior".
A small unobtrusive sensor (a Light Detecting Resistor) is incorporated in the finial. When a shadow falls on the sensor / detector the "controller" senses the change and turns on a special type of light emitting diode (LED). This little puppy has THREE different little LEDs built into one lens - Red, Green and Blue - RGB. Each of the three LED's brightness can be set to one of 255 levels - 0=off, 255 = max brightness. So - with a little programming magic - it can put out any color in the visible spectrum.
So, this piece sits there looking like a normal static hollow form with finial - and some little surface decorative "beads" around it. But when a shadow passes over its finial it goes into Display Mode - the little beads begin glowing - and changing colors. Shadow goes away - the beads stop glowing - the piece returns to being a normal static turning.
I shot the video with day light coming through windows on three sides so I had to cup my hand over the sensor to shade it. If the piece were top lit the sensor would be triggered from farther away - say by leaning over the piece examine it.
Working with these micro-computers / "stamp controllers" was just a wee bit trickier than I thought it would be. With just ONE controlled "component" things are easy. With two controlled components it still isn't that tricky. To get them to work together - the way you want them to work - well THAT can get tricky - IF timing is important - for generating a tone at a specific pitch - or tones whose pitch changes based on what a "sensor" is seeing, feeling or hearing. I'm working on a bunch of web pages about this "stamp controller" thing that hopefully will make things easier For The Next Guy - or Gal.
Will be posting links to the Youngest Sister and the Oldest Sister in the near future - hopefully.
Comments, questions, constructive criticism welcomed.
vid of the Middle Sister
