Veritas - Innovation in Tools
Cherry in rest
Cherry in rest
Cherry in rest
ronnyeelen
A small balancing vessel in cherry, 17cm tall if fully upright, 12cm wide.
It sits at this angle.
Re: Cherry in rest
Re: Cherry in rest
Toney Robertson
Very interesting.
Do you achieve the tilt with weights?
Re: Cherry in rest
I love pieces with no foot...
GaryG in MD
I've been making some myself recently. Who says things have to stand up straight?
I was working today on what I call a "rotator". I got the idea from Lynn Yamaguchi. It's a funnel shape (no hole in the bottom!) that comes to a point, and when it sits on a table, you can touch it and make it spin around. Semi-kinetic art.
Your form is very interesting because it's so tall. I echo Toney's question -- how did you make it stand up? ...Gary
Re: Cherry in rest
Re: I love pieces with no foot...
fgvanatta
Interesting piece. The last time I made one that stood at an angle like that, it was just the weight distribution in the wood - nothing that I did.
Frank
Re: Cherry in rest
Re: Cherry in rest, the tilting...
Ronny Eelen
... is achieved by leaving some more wood on the side near the bottom.
Someone asked me though why it always tilted to the same side of the vessel. I hadn't noticed that myself at that time. After some thought, I guessed it was because of the difference in density in the wood which is closer to the pith than the wood further away from the pith.
Thanks for the comments.
Ronny
Re: Cherry in rest
Steven Antonucci
hollowed eccentrically at the bottom?
steven antonucci
Re: Cherry in rest
Re: hollowed eccentrically at the bottom?
Ronny Eelen
No, nothing difficult like that. Just leaving some mass all around at a certain but non-specific height. You know, like when you didn't hollow out evenly... but this time intended.
Re: Cherry in rest
Density variations ...
Doc Green
Simply leaving more mass at the bottom will not, by itself, cause the object to tilt. It's the variation in density of the wood that causes one side to be heavier than the other, and this gives the tilt.
However, leaving more mass does two things: First, it keeps the object from simply falling all the way over, and, second, a greater mass makes the effect of the density variation more pronounced.
If the object were turned out of wood that is perfectly uniform, it would not tilt.
My 2 cents, at any rate. ~Doc
Re: Cherry in rest
Re: Density variations ... sounds correct
ronnyeelen
Hey Doc,
You are probably right. Thanks for this information.
thanks
Ronny
