A55 Smoothing Plane
Progress photos
Progress photos
Progress photos
I thought Terry Scott had a great idea of showing progress photos as a teaching tool. I thought I would post a few of my next Bowl from a board. This one is going to have the crescent moon shaped inlays. To start off I took a curly red oak board and glued a waste block to it. Then I tilted it out about 1/2". I turned this area as flat as I could get it from the center out.
I could only get it perfectly flat from the center out to the edge, not 90 degrees to this direction. I took it off the lathe and finished flattening the are with a hand plane. It only took about 8 or 10 strokes to flatten it.
Then I broke off the waste block and glued it to the other side and did the same thing on the other side.
To save on waste I resawed a piece of Padauk at an angle so I could use the same wood for both sides of the Oak platter.
Then I glued these to the Oak. You can never have too many clamps.
Tonight I will cut off the waste and then mount the glue block back on so I can flatten both sides. Then I will use the parting tool to cut the rings.
Here is a Walnut bowl in the glue up stage sitting beside it is a new mirror blank that I cut from the waste wood that I used to make the bowl. I cut circle for the bowl and the waste wood yelled, hey there's a mirrror in here so I listened.
Why is there a dark line in the walnut bowl. It was all Al's fault. He suggested I try cutting the rings from the other direction so the rings would fall off on the outside. I started the cut in my normal direction and then realized I had wanted to go the other way. So I did. I thought it would give me a chance to try out the polyfill black filler. Since it's water thin when first mixed it may actually patch this area. It's worth a try for the experiment both to see if it will fill the void and to see if has enough strength to hole the wood together.
Re: Progress photos
Re: Progress photos
bill crommett from Seneca
Good job, John. So far !
Re: Progress photos
Re: Progress photos wonderd when someone
Terry Scott
Wondered when some one would get the idea
Good one John
Re: Progress photos
Jeff Willaford
Thanks for the progress pictures John. I think you started something Terry.
