Micro Mesh
Micro Mesh
Micro Mesh
Dave Gelnett
How can you tell when your micro mesh is worn out? I know MM can be cleaned by putting them in the pocket of a pare of jeans but it must wear out sometime.
I have an old set of MM that I have been using for sometime now and a brand new set. I noticed that the old set gave a noticeabley shiney finish than the new set.
Re: Micro Mesh
Re: Micro Mesh
Doc Green
Dave, what I've observed with 400-grit (and other) sandpaper is that worn out or dull paper will tend to give a slick, shiny surface but it cuts very slowly, if at all, and doesn't remove scratches. What you get is a shiny surface with scratches embedded in the shine.
On the other hand, sharp sandpaper will remove scratches quickly, but the resulting surface is not as shiny as with the dull paper. What's happening, of course, is that the dull paper is burnishing the surface rather than cutting.
I have no experience with micro mesh, but perhaps it behaves in a similar manner. Do a comparison of the amount of dust produced by new vs. used MM. Chances are you will find the new produces a significant (but small) amount of dust, but the old produces practically none.
Good Luck, ~Doc
