Bowls without finish - aging effects?
Henry (Raleigh, NC)
I have a few maple bowls that I like in their current state - without any finish applied to the sanded/burnished surface. I know that with exterior exposure all unfinished woods seems to turn gray over time, presumably due to the combination of sun, water, and a wide range temperature. Does this (oxidation?) process just take longer for interior pieces? Or can I expect maple for example to stay relatively light colored in the long term if it does not have sunlight exposure and stays in an HVAC environment? I am discounting the effects of handling and fingerprints, I want to know about the natural aging effects.
Has any kept a turned piece unfinished long term and what effects have you noted?
Thanks
Henry
Re: Bowls without finish - aging effects?
Craig Daymon
I might be wrong about this, but I wouldn't expect a bowl, which is likely going to spend its life inside, will turn to gray. I would expect that through handling it will likely turn darker as it absorbs the oils from your skin. I think Raffan shows several bowls in his books with no finish and I don't recall any turning lighter or gray. (Course, those Australian woods tend to be a bit tougher so they may just be saying, "go ahead, try and turn me gray, punk!".)
Adrien
I think gray is due to weathering. Most woods seem to darken with time. And oily ones like cocobolo, teak, etc. probably don't need a finish.
Jorge Casta�eda
All woods are photo-sensitive, so they will darken with age, on top of that oils from your hands etc, will help to the darkening. All oils darken the woods.
You could bleach them now and then, but I dont like the feel of the wood after bleaching it. And most likely it will need to be sanded again.
A finish that seems to help retain the original color is lacquer.
Lets hear other opinions
Jorge
John Veerkamp
Maple will be relatively unchanged with age in an inside environment. If you want to keep hand oils from darkening or splotching the wood a light coat of wax will do just fine.
I cleaned a bowl that my mother had that had to be 80 to 100 years old. I don't know exactly what wood it was. Looked kind of like maple. It was turned green by a production turner based on the lines left from the cutting tool and the warping of the bowl. It was dark, kind of like aged cherry when I started. I think most of that was due to being used as a salad or serving bowl for all of those years. I had to use a cabinet scraper to get all the gunk off. The bowl was definitely not gray and had survived all those year still quite functional.
Dave Peebles Lyons, Ohio
Hello Henry,
I have a natural edged piece that I turned about ten years ago. It is very thin and made from Box Elder. It has been on a shelf at my place for all this time with no finish. I just checked it and it looks the same today as it did when I first turned it.
Best wishes,
Dave
P.S. I can't remember why I didn't put a finish on it :)
Aging dark vs. light depends on the wood
Craig Daymon
Also depends on what it is exposed to. Some woods seem to respond more to oxidization, others to light. Walnut gets lighter with age, I think from light as I've seen this on finished pieces. It might take longer than you'll care to observe, but it will, just check out Antiques Roadshow. Padauk will start bright orange and, relatively quickly, darken. Purpleheart, when first cut/sanded has a brownish cast that will oxidize in a few days to bright purple. The oily woods tend to darken.
I'd really like to see a good book or a computer program that would show wood colors and how they will age based on oxidation, light and different finishes. It would be very useful in creating projects with mixed species, especially for anyone creating marquetry.
georgetroy
You might try Clear Acrylic Sealer in a matte finish. I got mine from Hobby Lobby. I used it for a number of years. Setting on my shelf now I have box elder and hackberry which looks like the day I turned it 2 years ago. Most any finish will go over the Acrylic if you wish to take it further with tung oil, painting or burning. You don't get the different color effect like if you take Bradford Pear and put lacquer on it or oil. Should work great on Maple. Suggest you try a test piece and see if this is for you. Acrylic Sealer does not raise the grain a whole lot, if it does knock it back with very fine sand paper, not wet and dry black.
