Hugh: This has nothing to do with the posted link, but be forewarned that some variable speed controllers work quite well but have little torque. The variable speed controller I installed on my General 260 because I didn't want to spend the $1100 for a new one from General works quite well but the torque problem eliminates any prospect of roughing out a BIG bowl blank.
Basically there are 3 ways to get variable speed. Well 4 if you count step pulleys but I think most don't consider this variable speed. You can use an adjustable pulley like those on Reeves drives. Not very practical as a modification.
DC motors and controllers. They are very adjustable and easy to install but when you turn the speed down you lose a lot of power. To get around this you need a good step pulley but this kind of deletes some of the advantages of DC. Treadmill motors and controllers often have to be modified because many of them have circuitry that makes it start at the slowest speed each time you shut it off. This is pretty inconvenient for lathes. If you have instructions on how to get around this and you have some electronic skills then they do work.
AC variable speed. This is usually done with Variable Frequency Drives. The use 3 phase motors. They take 2 phase in and produce 3 phase out. The problem with these is they are kind of like small computers. They can be a little tricky for non electronic people to install and they must match the motor. However they lose very little power at slow speeds and are the choice of most modern lathes.
