thread chasing?
thread chasing?
thread chasing?
Bob Henderson
I just got a Robert Sorby thread cutting set. I've never chased threads before and I'm looking forward to trying it.
Can anyone with thread chasing experience give me a list of woods that take threads well?
Re: thread chasing?
Re: thread chasing?
Fred Holder
The best woods for hand thread chasing are boxwood and African blackwood. A few American woods will work fairly well: hard maple, Osage Orange, and Holly. The best wood to practice thread chasing on is PVC Pipe couplings. These give you a good thread holding capability on both outside and inside.
One can chase threads in a lot of woods, if you orient the grain of the wood at 90 degrees to the axis of rotation so that you are cutting threads in some side grain and some end grain. I've managed to chase good threads in pine using this orientation.
One thing that helps is to wax or oil the area being threaded and continue putting on more wax as the threads deepen. This really helps when chasing threads in woods less than perfect for thread chasing. I believe that Michael Mocho was using dish wasing soap when he was doing a demonstration of thread chasing in hard maple at the Seattle Chapter of AAW some time back.
I do have a handout that I prepared when doing a thread chasing demonstration. It is in PDF format and four pages in length. E-mail me and I'll send you a copy.
Re: thread chasing?
Rob Wallace
Re: thread chasing?
Rob Wallace
Bob:
I agree that blackwood is a great wood to thread, but it is a bit expensive to practice on! I've never tried boxwood, but is reported to be the the "threading wood of choice".
Fred is correct that hard maple is an excellent wood - it's one of my "threading practice" woods.
I have not tried practicing on PVC, but we have found that Corian or other solid surface material threads beautifully with hand chasing or with threading jigs such as the Klein or Baxter.
Slow down the lathe as much as you can and PRACTICE!
Good luck!
Rob
Re: thread chasing?
Richard Allen
Re: thread chasing?
Richard Allen
Boxwood. If you are just starting the best wood to learn on is boxwood because the wood will NOT be the reason that the threads are anything be perfect. Once you have the process working with boxwood you can translate that "skill" to other woods. Maple is frustrating to learn on.
Where to get boxwood? The source I use take MONTHS between order and arrival of the boxwood. Once the boxwood arrives it will be like it was always with you. Because my source is so sloooow I keep a supply of boxwood.
When practicing with the boxwood, make threads, turn the threads away, make more threads and so on and so on.
There is also some effort in fitting the male to female threads so some practice should be devoted to that effort.
You should be able to learn the skill in a day if you use boxwood. Using maple could find you frustrated in a few hours.
A nut and bolt chased out of boxwood can be silky smooth with little slop.
Re: thread chasing?
Re: thread chasing?
I have chased thread very well in Boxwood and Cocobolo. My Osage Orange was not very good, kind of old and buggy so the threads were mediocre. I'm fairly new at chasing. apparently there is a longer learning curve for softer wood because I have failed miserably with those.
PVC and Corian are great to practice on. I learned on PVC. I would put a chunk of 3/4" pipe in the chuck, chase threads turn it away and chase some more. Well actually they were beads at first but it didn't take long to start making threads. When I felt comfortable on the outside threads I started doing the same on the inside.
It's actually easier to chase the threads in wood than the PVC.
Re: thread chasing?
Re: thread chasing?
Matt Birchfield
For practice you can't beat Rhododendron... it's what I learned on exclusively. There's always lots of it available in the SE USA. It has a very fine grain structure, is very stable, and although usually plain, many pieces have wonderful swirling patterns. I make threaded boxes with it all the time. As somebody else suggested in this thread, I always use mineral oil throughout the thread-chasing process, applying it liberally with an old toothbrush. This method also removes wood particles from the threads. Hope it helps! (& everybody should try Rhododendron... it's not just a weed!)
Re: thread chasing?
Re: thread chasing?
Matt Where are you getting Rhododendron. I can get it green of course, it grows all over the place I just don't know where to get it dry.
Re: thread chasing?
Re: thread chasing?
robo hippy
One wood not mentioned, probably because it isn't available commercially is Mountain Mahogany. While I don't hand chase threads, Allen Batty told me it is the only other wood besides box wood that will chase good threads. It likes high desert in the western states, Sierra Mountains, so, from Washington down. I do have some, and when you get ready, e-mail me.
robo hippy
Re: thread chasing?
Re: thread chasing?
Matt Birchfield
John,
We have a farm in West Virginia where I get it. Some of the stuff I have is ~4" in diameter (we just happen to know that it's about 50 years old), and it's a truly great turning wood, especially green. When turning a hollow form, box, vase, etc., it turns beautifully and doesn't crack when drying. I generally use whole 'branch sections' with the pith. These are the pieces with the most character due to the numerous "eyes" that appear from undeveloped brancheswhich really pop when finished with a Danish Oil.
I haven't cut any in a while, but about four years ago we cleared a whole bunch from our woods, cut it into 18" lengths, end-sealed it and have had it drying since with very, very little pith cracking. While I'd be happy to sell some of what I have, anybody in the SE USA can go and harvest a few branches for free. I guarantee that it will be worth your while.
Re: thread chasing?
Re: thread chasing?
Bernie Weishapl
I have the same question as to where can you buy boxwood? I just got my thread chasers.
