Lathe Question
Paul Storck
Recently, I received an old lathe with no motor or drive shaft pulley and of course no manual. I found a motor that turns at 1725 rpm's and I can put pulley's on both the motor and drive shaft. My question is, what is the optimum speed for turning medium stock for a table leg, rolling pin etc. I can back into the correct pulley size if I know how fast the shaft should turn.
