My brother recently purchased a like new General model 260 and the tailstock will not lock in place He believes it is a 2004 model. Sounds like it needs a larger plate instead of what is stock. Is there a fix other than local machine shop?
It's not easy to diagnose from your description, but....
The locking mechanism is a large washer on a bolt, sliding under the ways. It sounds like the washer is too far from the tailstock. Try to tighten up the nut on the bolt that holds the washer.
I agree with Jesper, the bolt on the bottom needs to be tightened. There's a "bent" bar, the bolt tightens a disc or large washer against the ways so if the bolt is too loose, the tailstock won't clamp down tight enough to stay in place.
Hi Peter, It's also possible it's too TIGHT, not allowing the cam-action to take place...kinda' like having a pair of vise-grips too tight. I'm fabricating a longer handle for mine from stainless...a bit more leverage.
I have a 260 and the tailstock holds fine when the nut mentioned above is adjusted so the plate pulls up correctly. I do have to make sure the handle is well pushed down to get a good lock.
However, the somewhat poor holding of the General tailstock is not unheard of and some owners have made larger plates to get more grip on the bottom of the ways. IIRC the General plate is round and this results in less contact area with the underside of the ways than if the plate were of similar size and rectangular.
I turned a longer handle for the tail stock lock down and that seemed to help me. Just better leverage to lock it down. You can also adjust the nut under that plate for better locking.
Thank all of you for your help. The lathe is a 260-20 which I forgot to say. One would have thought General would have worked out greater contact for the washer. Part of the solution was to place a rectangular teflon washer above the original washer to center the bolt. Already added longer turned handle. Tailstock seems to be holding much better.
You will not believe the reception from General... Here I have a Used 1996 26020 that had a tail stock locking problem. As a last ditch stand I contacted General and explained the problem. Look what arrived in the mail today. A new cam with a 12 " handle in less then a week they did this.
Don't know if you spoke with Chris but I love the guys at General. When I had my first General with a Reeves drive, I called their Tech dept., Chris had me hold the phone to the lathe, found the problem, sent me a new Reeves unit and, while on the phone for over 45 min., literally walked me through removing the old one and installing the new one. Of course, every now and then he'd lapse into French but I learned a few words along the way......not sure exactly what they mean but they do come in handy! : o : )
Moved my lathe from 60 Hertz USA power to 50 hertz Europe - no problem, then emailed me the changed settings with no delay. Replacement handles were shipped promptly when I had broken them (my bad habit of hitting the handles with the tool) at a reasonable cost.
