Long story short, a neighbor game me a piece of a box elder branch yesterday -- about 10" in diameter and maybe 20" long. He said it's been drying for 4 years -- I can believe it because it's quite light in weight. It doesn't appear to have been end sealed, but it has not cracked, and it has a beautiful flame pattern in the cross section down the pith, evidenced on both ends -- slightly browning, but still reasonably red.
The question is, if you had a piece of wood like this, what would you make to maximize the beauty and presentation of the flame in the final object? I figure I can get two, or maybe three pieces out of it if I'm careful. I'm thinking one end-grain HF, perhaps a shallow end-grain bowl, ... OR...
Please give me some more ideas. I want to use this to best effect. ...Gary
I just got another load of box elder last week, and plan on making more bowls & vessels to accentuate the flame as much as possible. It's one of my favorite woods available locally (central Iowa) that we can get reliably around here. The amount of "flame" varies not only from tree to tree, but within a single tree as well.
With box elder I have done standard bowls, natural edged bowls, and hollow forms to try to capture the red flame (as well as bluish mineral inclusions). It sands nicely, and in general does not crack or distort much if turned wet, dried, and re-turned.
One of my favorite forms is an end-grain hollow vessel with a collar (usually African blackwood or ebonized hard maple) similar to the one below. It tends to show off the flame symmetrically as much as possible.
Wish I had a photo of my friends piece. He had just about what your talking about. He turned a ball hollow form. He hollowed through the side so the area around the pith which had all the color was on the sides of the ball. It looked great He only had minor checking in the pith areas which he left as is.
If I was doing that I would turn a rough ball shape and then look at how the color goes. Then you can rotate it anyway you want orient the color the best. Then mount it between centers so the color goes in the direction you want and turn a tenon for the chuck or faceplate. Then turn your vessel.
I would turn it quite thin if you leave the pith in it. It will also tend to elongate where the pith is so you might get some funny lumps if it isn't totally dry. If the pith is located on the equator so to speak then both ends will elongate which doesn't look as funny as an off center warping.
Two part bleach, sold in some paint stores, will make the light colored wood almost white but does not seem to change the flame. I've attached a picture of a small hollow form that has been bleached.
Turn it green. Box Elder is nice to turn when it is green but stringy and tear-out prone when dry. But...welll worth the effort!
