I have some powder post beetles from some wood I just picked up, and I'd like to save as much of it as possible. Anyone got a sure fire way of dealing with the little buggers?
If I "quarantine them" in plastic bags, will they suffocate? How about setting off a bug bomb in that bag...
Prior to reading that I would have said try malithion and/or permethrin, but the post at the above site says "BoraCare".
I have used malithion and permethrin with partial success, but I must admit, never complete success. I store a lot of lumber in an old haybarn, so I have never expected complete success. They mostly attack the sapwood. Of course that's not fun if it's a species where you like the sapwood.
I have used Bora Care with good success on buildings. Good stuff. You can buy it from a company that supplies termite contractors. The last I bought was $85 a gallon. You dilute it 50/50 with water and spay it on, or you can dip the pieces if they are small enough. Bora Care is a borate suspended in glycol. Teg glycol is a penetrant and caries the borate into the wood. Don't know what effect it would have on the appearance of the wood or finishing it, If this is turning wood as opposed to construction wood. The Borate has very low toxicity to humans, but the glycol is poisonous.
You can also that the pieces by putting them in a black plastic bag in the sun. If you can get the wood up to 130 Degrees all the way through, it will kill them. This is less reliable and may damage the wood if you are not careful.
You can also put dry ice in the the bag and let them suffocate in the Carbon Dioxide. I have not experience with this and it would work, but seems unreliable to me.
You can also use the bug bomb or other more toxic stuff like Methyl Bromide If you can get it. Viacane (I think) is another. The methyl Bromide is extremely poisonous and must be treated with great respect, but it will penetrate tot eh center of the wood, kill the bugs and once you air it out will leave little or no trace in the wood. But It will kill you too, so be careful.
Put it in a plastic bag with Mothballs. That worked for a friend of mine who had a piece already finished and didn't want to destroy it with nasty chemicals. Someone on WC recommended it and it worked.
If the wood blanks are not too large, microwave the wood. It does not take much microwaving to kill the bugs. I have also used a small needle and syringe to inject malathion solution into the bore holes -- this works, but can get tedious if you have a lot of holes/bugs.
The Boracare (In EU Boracol - presumably the same) works by impregnating the wood with borate, aided in penetration by the glycol. As the larvae chew through it on their way out to become flying insects - and breed, they eat the (to them ) toxic borate and die.
Since that larvae may live in the wood for a long time - maybe years - it is a long term solution, not an instant kill.
The borate in the wod is not a hazard to humas, after all you are not going to eat it, are you?, but the glycol in a sparay atmosphere is not so nice. In an enclosed atmosphere it mght be better to brush it on in undiluted strength.
