Would a Cant Hook or a Log Peavey be better. They both seem to do sort of the same thing. Of course I'll probably end up with whatever I can either find at the flea mkt. or simply try and use my forge and welder to build one. Either way I would like to know which one is best. I have what I call a log lift. It rolls the log and then lifts it off the ground. It's more or less like a Cant Hook or Peavey but without the spikes at the end of the pole which makes it hard to roll anything bigger than about 12 to 16".
I have a cant hook made by Stihl that is steel tubing. It also has an optional attachment that is a T fitting meant to jack the log off of the ground for cutting (I think they call it a timberjack in that configuration.) I have handled logs up to 20" in diameter with it, and 4' long, flipping them up on end to load into my truck.
Sure useful for field work, and the steel tube is a nice light/strong upgrade over the wooden ones my buddies have.
The peavey works better only when you use the spike in the ground. I would use that to change direction of the log. Spike to the ground, then lever against the log. When you get real big, I like to pull my van next to the log, wrap a chain around the log, hook one end of the chain to my trailer ball, the other end to a come-a-long that is also hooked to the trailer ball. You can roll huge logs that way with a mechanical advantage of the wrap. I once snapped the handle of my peavey, that's 3" of hard maple. I was a little younger then, and didn't always work smart. Now I use the van trick when working the biguns.
I find a Peavey to be much more versatile... my dad and I routinely roll 30" logs with a pair of them. The point on the end allows you to get leverage under a log to nudge a log into position by lifting or pushing while using the ground as the fulcrum. Peaveys can even be used on a smooth surface like the deck of a trailer. Cant hooks are best for rolling logs. (I hope this all made sense... if not I can try again.)
John, I have three cant hooks ranging from about 32" to 60". I use all of them around my sawmill all the time. I have a peavy, but frankly I "cant" make much sense of it, and probably couldn't even find it. I can see where it might be a pretty good "Pry Bar" for rolling logs on the ground as mentioned above, but I just haven't ever seen much advantage to it.
If you haven't priced them, cant hooks are more expensive than you may think. Seems like a paid about $75 for my larger one 10-12 years ago. The others have just sorta been around for a long time. Probably flea market specials.
If you use one much in logs larger than maybe 24" you will probably want to heat and bend the hook outward a little. It's hard to get a bite on larger logs with them the way they come from the manufacturer.
thanks guys. I think I can just weld a little toothed piece of steel on the bottom of what I have and it will function like a Cant hook. I'll sharpen the point and maybe heat and rebend the arm and it might work for rolling these things. It has a 5 foot x2 1/2" steel bar attached so it won't bend or break. It's just kind of heavy to use.
I find that having two is a great advantage when dealing with really big logs. I just can't seem to get it to rotate far enough with one to keep it from rolling back, so I tag team it with the other until it is steady on its own.
The problem I have right now is the biggest log is stacked on top of the other two. I can cut it up with my new 20" saw blade but only if I can roll it over. This means rolling it off the others. With my luck it will start rolling and just keep on going and take out the back deck.
