12TPI vs 20TPI
12TPI vs 20TPI
12TPI vs 20TPI
I wanted to know the difference thread pitch makes in the time it takes to cut a thread. Of course a larger thread moves faster than a fine thread but I wanted to know how that affects hand chasing at slow speeds on the lathe. Mostly because a lot of lathes cannot go below 500 rpm.
I ran the lathe at 240rpm and chased threads on a PVC spindle that was 3/4" in diameter. I ran the threads 1 1/4". The 12TPI took 3 seconds to travel the distance and the 20TPI took 6.
What this tells me that when you are cutting only 3 to 6 threads the time it takes is about 1/2 second for the 20 and 1 second for the 12. That's not a lot of difference so for all practical purposes they are about the same.
Technically if your lathe won't slow down the finer thread might give you little more time than the course thread but it's probably more about your skill at chasing than it is about the thread pitch.
Re: 12TPI vs 20TPI
Re: 12TPI vs 20TPI
Texian
John,
240 rpm would of course also be 240 threads per minute, or four (4) threads per second. At 12 tpi an inch of threads would take three (3) seconds, and at 20 tpi an inch or threads would take five (5) seconds. Either one would be way too fast for me. Love your box in the other "thread".
Re: 12TPI vs 20TPI
Re: 12TPI vs 20TPI
Allen Neighbors
John, I wanted to chase threads for about 5 or 6 years before I ever saw it done. I came home, and tried it on my little Vicmarc. :( The slowest speed on Little Vic is 640 rpm (based on the Vicmarc speeds with a 1140 rpm motor, and my lathe with a 1725 rpm motor). I had a tool to make 20 tpi, I think. It took a lot of wasted wood, but I finally got some usable threads on the inside of a little box... I never got any on the lid.
Now I chase threads on my 1640 at about 150-200 rpm with the larger threader... don't know what tpi it is, but I think it's around 12 or 10 tpi. It was made for me by a friend in Australia.
Question: How do you find time to do all this stuff you do? Are you twins or triplets, and have just been keeping us all in the dark? :D
Re: 12TPI vs 20TPI
Re: 12TPI vs 20TPI
Allen I actually fuss at myself for wasting so much time. There's just so much to do. I wasting time right now watching the Tour De France. I'm always hooked on that. Fortunately it will be on again tonight because I need to turn. I dried a piece of wood last night for a finial for an ornament so I need to get out there and turn it. I plan to turn a small bowl this morning, then I'll mow the yard and get the laundry going. then I plan to go for a 30 mile bike ride.
Sometime during all that I've got clean the shop. It's a mess. Haven't planned tomorrow yet except for a trip to Nashville to pick up my son. I'll probably work on those 36" logs some more. Gotta figure out how to pick up the big one so it's not resting on the end I'm cutting off. That will be a challenge.
Re: 12TPI vs 20TPI
Re: 12TPI vs 20TPI
bill crommett from Seneca
Do you see now, Al ? John is just well organized ! Some got it and some don't . (I'm one of the latter group).
Re: 12TPI vs 20TPI
Re: 12TPI vs 20TPI
I do make a list of all the things that are important and need to be done. Then at the end of the day I find that there are several things that didn't get done. This usually means they weren't as important as I thought they were.
Got the ornament turned, then turned a small really nice shaped bowl. Got the yard mowed. I'm fueling up for the bike ride now. Thought I'd better get on the computer and look at the weather. It's clouding up pretty good. Of course around here it can be perfectly clear and in 2 hours time build up a monstrous storm. I've been rained on many times while riding.
Re: 12TPI vs 20TPI
Chuck Jones - West TN
Lists make the difference...
I also make a list of the things that are important; then forget to look at it.
Re: 12TPI vs 20TPI
You and me both, Bill.
Allen Neighbors
John, you amaze me. Would like to meet you and pick your brain, sometime.
Re: 12TPI vs 20TPI
Come on down
