Veritas - Innovation in Tools
Work Light Options
Work Light Options
Brian McKearney
Work Light Options
Brian McKearney
I moved my Oneway 1640 to a new location earlier this year. I have mostly been roughing bowls over the past few months, so good light hasn't been so much of a concern, but I would like to rectify that problem. I'm interested in purchasing a Moffatt work light and I was wondering how folks typically mount these lights. My 1640 is outfitted for outboard turning as well, so I would either like an option where I could move the light to use at either end or maybe I need to get two lights.
I'm currently considering some kind of steel bar mounted from the ceiling where perhaps I could stick the Moffatt Light using the magnetic base - is the magnet strong enough to hold it from the ceiling?
I have looked at the Sander's Light Stand - it looks nice, but it seems a bit expensive for what it is. Maybe that's the best option?
What kind of lights do you use and how did you mount them? Any ideas and/or pictures would be much appreciated.
Brian
Re: Work Light Options
Steven Antonucci
I have a cheap magnetic light
steven antonucci
I stick it to the lathe wherever it is needed. Works well for thin turning where I use the light to gauge thickness. If you look at the Hat#2 post I made yesterday, you can see the round base of it on top of my headstock. Plenty strong, and I move it to my bandsaw when I need it.
I think it was $10, and I use a floodlight bulb in it because I had one.
S
Cyril Griesbach
I have a Moffat light on a magnetic base but I don't think the Oneway's rounded surfaces will provide enough surface area for magnetic attachment. A friend of mine has a floor lamp base ( no harp, fixture etc) with two Moffats attached that he can move at will.
Michael Mocho
The Saunders light system sold by Oneway is a great design, but like you, I hesitated on the price and decided to try and build my own. It�s funny how we spend a pile of money on a good lathe, then get cheap on details that are still important.
I bolted a wooden rail on the back of my lathe (a Oneway 1640) that is simply drilled through with a series of 3/4" holes that accept 3/4" dowels that hold the pivot bars for the lights. I think I spaced them about 10" on center on the 2" wide maple rail, and the lights sit on offset wooden risers to clear the back end of the tool rest base.
I highly recommend the Moffatt flex arm lamps- they are not cheap, but you will only buy them once and and they don't fall apart like all the cheap swing arm lights I used to buy and have to repair and replace. They have a heat sink in them that allows for high wattage bulbs but still stay cool.
Hope this helps.
-Michael
I have a cheap clip on halogen light from one of the marts. Works great, but you have to have something to clip it to.
I also have a Dentist's light. (gloat) Its great, but I scored it for free. New, It would have been several thousand bucks. The bulb is about $90. The silvering came off the reflector and they wanted about $600 for that. (I coated it with foil tape.) It is located so that it can work for the a the, the DP and The BS. Now if I could just get those hollow forms to say AHHH!
Brian George
Barry, Appreciate the good laugh...
Mike Mills
Mike Mills
When I decided to add one I made it myself. My lathe is against a wall so it may not work for you. A company called Sam Ash sells stage supplies and carries microphone extensions (flexible). Two 19� sections and the small base was about $20. The light I got at Home Depot for about $10 is a 100w outdoor spot light. The fixture is less than 2� across so it has a very small profile compared to a fixture to accept standard light bulbs.
I mounted mine to the wall and with the 38� gooseneck I can swivel it any place I want and have it out of the way. I typically only use it when finishing or when working on the inside of a bowl.
You should be able to mount one to the ceiling also.
Mike
Re: Work Light Options *LINK*
Stuart Johnson
I use an old goose neck desk lamp attached to a floor lamp stand. When I was at Lowes the other day I saw a new LED work lamp. It has 80 LED bulbs, a magnetic base. The bulbs are in two folding sections (like a book) and are powered by a rechargeable battery. It is hard really see the light with the type of light used the store. It looked like it would work pretty good but for $35 I didn't want to buy it just to try out.
Lowes LED Light
Jeff Willaford
As for ceiling mounting... my Moffett did not want to be mounted upside down. Gravity would overcome the flex shaft and I never could keep the light in the position I wanted. I fastened a piece of 2x4 to the wall, mounted the light base down and it now works like a charm.
Track lights
You can put several lights of whatever configuration that you want. I've got two compact fluorescent par lights and one incandescent screwed into this fixture.
You can point wherever you want.
Chuck Engstrom
Hi Brian -- I mounted a Moffatt on the back end of my Powermatic banjo with one of the screw-on Moffatt mounts -- see photo. Craft Supply has these in their catalog, very low cost, so buy several and you can move it about as you wish.
The working end of the Moffatt mounts are really no more than a 1/2" shaft with a bit of a groove to capture spring-loaded balls to keep the light from jumping off the mount. If your light will always be right side up, the groove isn't really needed and you can mount on a stub of 1/2" metal rod epoxied into your banjo or wherever else you need it.
Best--
Chuck
Re: Track lights- Modified!
Dave (PacNW)
I use the same set-up over my lathe. I got tired of replacing the special lights for the cans, 10 minutes with a pair of snips and I can use
florescent floodlights. Use less power (23watts per light) and 10 times the light, as well as costing 1/3 as much!
Dave (PacNW)
Re: Track lights
Dave Gelnett
What about the window, have you ever broke the glass with something coming of the lathe?
