THE WOODRAT IS BACK!
Tormek jigs for your grinder
George Taylor
George Taylor
In my never ending quest to improve my sharpening (I am a part time turner that doesn't nearly get the "practice" I would like...) I came across this new jig (at least for me) and it peaked my interest. I am mired in the complex that I am one tool from being really good at sharpening. :D
Does anyone have any experience with the Tormek jig for a grinder (BGM-100)? If you already have a grinder, is it a decent alternative to the full Tormek system?
It would be great to order it during SWAT where all discounts come in handy.
Thanks
George
Re: Tormek jigs for your grinder
John Leonard
Hi George, I have one on my grinder that I use for shaping and use my tormek for sharpening. I think my Wolverine system does as good a job of sharpening. John L.
Jim Sebring
I have the setup on my 8" dry grinder. Like john, I use it for shaping tools. I sharpen on the Tormek - I hate to grind away good steel on the dry grinder. I also have a Wolverine, but don't use it often.
David Walser
George,
I have the Tormek dry grinder set up and I also have the full Tormek system. I prefer the Tormek jigs to the Wolverine jigs, so that's what I use with my dry grinder. Since the Tormek produces a much better edge than does the dry grinder (80 grit v. 1,000 grit), I prefer using the Tormek to sharpen my turning tools. However, when starting out with a new tool, it's much faster to shape the tool on the dry grinder (using the Tormek jigs).
Good luck!
Bill Grumbine (Kutztown PA)
George, I have been using a Wolverine on a grinder for 15 years now, and a grinder freehand since I started turning 17 years ago. A few years ago I bought a used Tormek at a great price thinking to use it for my flat work tools. It just sat there. I did sharpen my pocket knife with it, but it was a very expensive way to get that job done.
When Tormek came out with their bench grinder attachment, I decided to give it a try. I am now converted to Tormek for my turning tools. :D As has already been mentioned, I use the bench grinder to shape the tools, and then maintain them on my Tormek. There are several benefits to this. First, I grind away a lot less steel. Even though I consider myself pretty good with a grinder, the Tormek still takes less steel away when I use it. This might be inconsequential to some,and maybe in the scheme of things it might not be a tipping point all by itself. But wait, there's more! :b
Two huge benefits to anyone using this system for turning tools are health and safety related. In the first place, the amount of silica and metal in the air is reduced to practically zero by switching to the wet grinding method Tormek uses. I wear an air helmet when I turn, but still, I get that stuff in my lungs just about every time I grind a tool. Reducing my grinding to initial sharpening lessens that greatly. The second is the issue of sparks. I have never had a problem with sparks, but it is always a concern when wood chips and dust are concerned. Wet grinding equals no sparks, period. And then, there is the benefit that my tools have a sharper edge. I noticed an improvement in the surfaces I was getting as soon as I started using the Tormek. I still start, and will continue to start with 80 grit. But now it goes even faster.
One very large benefit to me that not everyone will require is the portability of the Tormek. I have demoed and taught in more places than I can remember, and often, the sharpening setup leaves somewhat to be desired. I have been greeted with aluminum coated wheels from a previous user in a common shop, improperly set up Wolverines, poorly built home made knock offs, wheels too fine and loaded with metal, no wheel dresser, etc. The list goes on. Now I can grab my Tormek and go very quickly and easily, and I know exactly what I have to use. It has been with me on two demos already, one of them being the vendor show in Hartford.
One thing I did was to add the black wheel. I don't think it grinds any faster on exotic steel, such as my Thompson tools, but it sure seems to last a lot longer between dressings. Maybe it lasts longer because it grinds faster. I don't know. That is an issue for engineers to ponder. It was not hard to change my tools over, while retaining my own particular grinds. Some of the settings in the book worked for some of my tools, and for some, I had to tweak it just a bit. But once that is done, it is done. I never thought this would be a tool for me, but I have really been impressed with how it works.
Fred Holder
I have the Tormek jig set up on each side of my Dry Grinder. I use this set-up primarily for sharpening bowl gouges with the Ellsworth Grind. Since I have Diamond Grinding Wheels 80 grit on the left side and 360 grit on the right side, I don't use the Tormek as often as i did before getting the Diamond Wheels. However, I believe the Tormek creates a sharper edge on any tool. And, of course, there is no dust from the grinding wheel. I have not noticed much dust from the Diamond Wheels either. Incidentally, the Diamond Wheels make the dry grinder with the Tormek Jigs about as expensive as a Tormek.
Bill Turpin in WNC mountains
Recently wife and I took an all day hands on class with Alan Lacer. We were told to bring every skew we owned...all nine of them. Had a month to get them ready. I tried to shape a 1" Crown skew to Tormek standards. Did the rough work on the dry grinder mostly freehand. Every time I went to Tormek, it was still not properly shaped. After 2 plus hours over several days on the Tormek, I bought the BGM100. Five minutes later, I had the shape. If you want to reshape a tool, it is worth every penny!
Don Geiger
Don Geiger
I have a version of the Geiger's Vertical Solution that works well back and forth between a bench grinder AND a Tormek. It takes about 10 or 15 seconds to move from one to the other and gives you the same results. Unlike systems offered by Tormek and others to do this, the Vertical Soltuition enables you to use conventional jigs (Ellsworth, Vari-Grind etc.). It also compensates for the diameter of the wheel and the difference in axle height. It comes with good instructions and set up gauges.
Don
George Taylor
Follow-up: Tormek jigs for your grinder
George Taylor
I purchased the BMG-100 and installed it over the weekend; so far I just worked on my bowl & spindle gouges and I have to say I am impressed (even with an 80 grit wheel that needs a little dressing). Worked on one radius skew and did fairly well; so much so that I had to get a scrap and play around with it. :) Instructions are very good; I am not sure I will move up to the full Tormek but I will get another BMG-100 for the other wheel and a finer grit stone.
Not affiliated with Tormek except as a satisfied customer.
Thanks for all the feedback.
George
Re: Follow-up: Tormek jigs for your grinder
jimmy edwards
George in relation to the center axis of your grinder what distance did you put the center of the jig bar? As to the height and front of the grinding wheel. I bought the jig also and am going to mount it this week. I've used the Tormek nearly 5 years.
George Taylor
George Taylor
I followed the instructions in the manual and measured the distance from the bottom of my platform to the center of the grinding wheel and deducted 2" for my 8" grinding wheel (for the overall height); then I took the distance in the diagram from the outer edge of the grinding wheel to the outer edge of the Tormek platform for the width. I tried to be careful that I stayed square. Mine is mounted on MDF so I drew a lot on it to try and keep things lined up.
I hope that makes sense.
George
Fred Bearman (Port Huron, Michigan)
To me this so much represents the beauty of this setup - you can start out with the BGM-100 and the appropriate Tormek jigs, and if you decide to move to the full Tormek later you haven't lost a thing. I know that I struggled for so long over whether I should go with a Tormek, or a Wolverine, or whatever - had the BGM-100 been available then I would have gone with that for a fairly minimal cost, and then made good decisions around that basis. It certainly makes a full grinding (whether reshaping or with a major ding) a breeze, and then on to the Tormek without even having to take it out of the jig.
