Celtic Knot,What went wrong?
Andy Lincoln,in Dearborn MI
Hi All,
After seeing a couple demos and reading a brief tutorial I built a jig for the table saw to cut the splines to make a turning with a Celtic knot.This piece was just a test of both the jig and my turning.As you can see it didn't quite work out.
I set the height on the table saw to leave 1/32" of material on the top of the blank and filled the area with the spline.Rotated the blank 90 deg and did the same cut,gluing,trimming and sanding each time for the remaining sides.
When my cuts were finished I had a reversed "z" on each face of the blank,just as what was in the You- Tube video "The Homework Ultimatum" which is where my inspiration to make this style turning came from.
The woods used are curly maple and walnut.I had some down time today as I ran out of pen kits after using the first 5 I bought : ( Gotta get more
Thanks,
Andy
