Ditto +
I'll reiterate the vote for the superiority of the Kobra.
I made my own restrained hollowing rig, based upon the Jamieson idea, with some improvements.
My rig would take straight boring bars up to 1" diameter (18" depth) and stepped bars of any length. I also incorporated a laser boom with an articulated tip to compensate for parallax with off-set cutters. I sold the rig through the WC classifieds to Chuck Engstrom because I put in my order for a Kobra to fit my Stubby 1000. It worked quite well for hollowing in the 12" depth or 10" wide ranges. It did, however, have more vibration than I wanted with the longer bars which would aggravate my carpal tunnels and T.O.S./B.P. issues.
I recently got my Kobra. I chose this system over all of the other articulated systems because it allows a more "natural" turning experience with the rear handle, and because it eliminates what I see as a safety hazard with the others that use a scissors-type of arm; in the event of a catch or major problem causing a shock and kick-back, the laceration (or loss) of right hand fingers is a real possibility. The Kobra's thrust-bearing knuckles eliminate that issue, and make lateral movement of the tool completely free and totally supported even when presenting the tool at an acute angle. My Kobra is shown here with the new handle I fitted for greater comfort to my right hand.
The rear-mount handle (mine or the "stock" bar) allows me to hollow from positions at the left, end, or right sides of the lathe (270� to the workpiece) with full leverage on the boring bar.
The Kobra system, at about 40 lbs. total, is also more robust than others so it transfers any cutter vibration directly into the bed making it (almost) vibration free. The hardened "goal post" rest means that the boring bars will glide smoothly with no flex or vibration across its entire length, and again, works to suppress vibration. With adapters I have, the Kobra will take and hold every hollowing tool I have from 3/8" Ellsworth style, to John Jordan bars, up to the 1-1/2" monster I have if I want to go more than 22" deep.
My set is a bit of a prototype as Al and Jerry came up with a new pressure plate made so that the entire unit can be "dropped" into the bed at any point rather than having to remove the tail stock and then slide everything in from the end. For people with long-bed lathes, this is a great improvement.
