A Pithy Question
A Pithy Question
A Pithy Question
For all you wet end-grain turners:
If you do a hollowform with the pith included in the bottom, do you
a) leave the pith in for drying or
b) drill it out and then plug it when dry or
c) ???? [details please]
Re: A Pithy Question
Allen Neighbors
Mark, when I turn a green form from start to finish (is this what you said?), I purposely turn it very thin (at least down to 1/8"), and leave the pith in. I turn the bottom so that it's concave, and thinner than the top, since this gives it some advantage... it doesn't crack as easily as those with thicker bottoms, I believe.
While I'm turning the inside, I keep the outside wet by spraying with soapy water, if I haven't wet sanded with DO. This helps to slow the drying down, so it doesn't go oval before I get it completely hollowed.
Then I also spin it "dry" and seal the outside with a lacquer wash (if I haven't already wet-sanded with oil).
Then I keep an eye on the pith... if it starts to crack, I use CA on it.
This is just how I do it... not necessarily the best way...
Dick Hines
Dick Hines
Putting the pith off to one side will help too.
Thanks
For the suggestions.
Since the piece was turned with the pith dead center on both ends, and since I don't use soap on turnings (anymore), I've decided to drill out the pith with a 3/16" bit and wrap up the outside leaving the interior to vent.
Vee zhall see how it goez. :)
Re: Thanks
Keith Newton
Of it is flat, you might need to drill. If it is domed or conical, you can leave it in, if it is thin. This allows that defirential ratio between tangential and radial to stress relieve.
david
Mark:
On some softwoods, like the NIP, the pith is fairly large in diameter and well, pithy. I can usually use CA glue and sawdust to solidify the center and this works for most cases. Sometimes I drill out the core and plug the hole with a dowel, but it helps when the dowel wood color matches the turned piece. Keep in mind that the bottom while wet is the most extreme condition of end grain you will find on the piece, and the bottom may collapse on you if too much pressure is placed on it. Been there, done that ;-).
Gently Concave
but about 1/2" thick (this is for a funerary urn) and 5" in diameter at the contact ring.
I'll probably plug it with a dark contrast wood, rather than trying to hide the dowel, before I coat the interior with epoxy.
This was the first piece made with my new Kobra hollower and my old Jordan boring bars. Man-o-man what a difference! :D
Thanks, David
piece is ambrosia silver maple with a solid pith. I drilled out 3/16 to relieve contraction stress. I will have to watch it though.
You're right, Dick!! I should have thought of that
Allen Neighbors
Re: Gently Concave
Keith Newton
5" r is good, but 1/2" calls for slow.
Just keep it in a paper bag for a week or two, and it should be fine IMHO.
