I hope I can describe this correctly. I have a rather large hollow form made from a whole log with the pith centered. The log had some bark inclusions, which I want to keep, and I also wanted to have a contrast in color, so I kept some of the sapwood. Leaving the sapwood meant that the bark inclusions were in tact as well. Now I want to clean up the inside, but my steady rest doesn't seem to want to cooperate. It kinda "clunks" every time it hits one of the inclusions. The inclusions are long enough to not allow moving the steady so it wouldn't run over them. Filling the inclusions with custom fitted pieces of scrap wood, and then removing them later, is all I can come up with. That's a lot of time consuming fitting of pieces. Any other ideas? TIA
Barry nailed it. I did that with a square piece once. I mounted a piece of plywood with a square hole in it and turned that round. Then I put the steady rest on that. I was able to hollow the square piece without chatter. You could hot glue a ring to the form and put the steady rest on that.
I can't believe I didn't think of that as I have used the exact same technique last fall. I think I even know where I hung that ring on the wall. What do they call that... a brain fart?
I've made several rings for this purpose. I use MDF and hot glue the ring in place. Then turn the ring to true it up and then set up the steady rest.
I've also done this on naturnal edges bowls or ones that have voids along the edge. It helps to keep the bowl from flying apart and keeps it from vibrating when holowing it out.
You don't need to much hot glue. Just spots here and there works fine.
