Veritas - Innovation in Tools
Hand Held DIY Laser Wood Burner *LINK*
charlie belden
Figured somebody had made a handheld laser woodburner. Stumbled on this one while looking for videos on the Arguino micro controller I picked up at the Makers Faire I want to use too control small stepper motors I want to use in a piece. This pen leaves the laser on and when close enough to the wood, begins burning it.
Leaving the laser on is dangerous - especially since this one is in the infra red spectrum and not normally visible - but still able to damage your unprotected eyes. That can be taken care of with a filtering collar at the tip - that you can still see through. And an on/off switch on the pen or a foot switch could turn it off when you wan. A pressure switch, set to go on when the tip is close enough to the wood, could also be done - and be safer.
Can't do what you can do with a laser engraver - but it is hand held , hand controlled and can pyrograph wood.
What's the pyrgaphed piece contest entry cut off date?
http://www.instructables.com/id/Laser-wood-burning-pen/
Re: Hand Held DIY Laser Wood Burner *LINK*
Colin
Looks really good but I have been unable to find a laser like he used on eBay. Anyone track down a supplier?
Contest ends 9/30
Click the contest banner at the top of the page for more info.
Using THIS Tool Qualify For Contest?
charlie belden
Ellis:
Before I go hunting for parts, building a laser pen like this, learn to use it and do a piece with it
- does a hand held, hand controlled laser pyrography pen qualify for the contest?
If I recall correctly, as long as it's hand held and hand controlled a laser pen entry would qualify. And now that I've provided a link to a video of an example of this type of pyro tool, the judges can see what it is and how it's used in order to determine if using one on a piece would qualify for the contest.
I await the judges decision ; )
(And I just got a programmable micro controller, some small stepper motors and a few cell phone vibrators I wanted to use for a movement AND sound piece - with an infra red sensor to detect humans nearby and "turn on and off" by itself.)
I'll check with the judges
I don't see any reason why a process or tool that is hand controlled can't be used for our pyrography contest. But, it's up to the judges. We'll get back to you.
Harry in Beautiful Downtown Kulpsville
Be VERY careful with a device like this! While looking directly into the device can, and will, do damage to your eyes, the beam can be reflected off shiny objects. Once reflected, who knows where the beam will strike. A nifty idea, but one that must be handled with respect.
SAFETY IS RULE #1
charlie belden
I ABSOLUTELY AGREE. Lasers require Eye Protection and careful use, and I'd want some built in, redundant, safety feature like
1. a proximity switch that would only allow the laser power if it was in contact with a non-concuctive material - like wood
2. a dead man foot switch that would cut the power to the laser if your foot comes off the switch
BOTH would have to be used to power the laser and some sort of monitoring device to detect if either safety device wasn't able to do what its supposed to do.
The set up I posted the link to the video on doesn't appear to have a lense to focus the laser beam, relying on having to be very close to the working surface to be able to burn. It appears the beam spreads quickly the farther it is from the working surface. If that's true, the effect of the beam drops with the square of it's distance to whatever it's shining on. What that distance is to not cause eye damage is one of the many things I'd want to know for sure before I used one. And I'd be concerned about how a magnifying lense used to see details might be dangerous in terms of eye damage - say from reflected laser light.
Lots of things to learn - and understand - before I make and use a laser pyro tool.
Even though just turning a piece has its inherent dangers/risk, I figure my skin is sort of self sealing and I've got a safety margin built in when it comes to blood volume. Eyes, on the other hand, are far more vulnerable - to permanent damage - and we're only issued two - which seem to wear out way too soon under the best of circumstances.
Don Evans
For pyro work on wood it doesn't look practical to me.
Big problem seeing what it is doing at the burning point on the wood. The light reflection would make it almost impossible to see what you are doing.
Also it doesn't have a way of changing the tip as the pyro unit we use now do.
Really good pyro work needs both these capabilities.
If you just want to char stuff use a Weller soldering 120 watt gun.
Don
I'm pretty sure early cars weren't Ferrarris
charlie belden
Nor were the early pyrographic tools as refined and flexible as today's commercially available pyro systems. And I doubt that early pyro set ups were all that safe either. Granted, they couldn't blind you - unless you REALLY worked at it.
I see the potential. Other's may only see the current shortcomings. Half Full or Half Empty - depending on one's perspective.
Adding the safety features to keep it from blinding you, or the cat - and with a lense to focus the beam to a nice tight pin point - some pretty fine stuff could be done - by someone with good eyes and a steady hand. The idea of drawing - with light - seems pretty interesting - to me. Other's mileage of course may vary ; )
Re: I'm pretty sure early cars weren't Ferrarris
Don Evans
Of course all new things need work to continue to evolve Charlie!!
That wasn't the point, your query was for today, now, not the future was it not?
If you want to take this device and run with it, then go for it, you seem to want validation but the answer to art isn't it the material devices used to make it but in the hands and mind of the artist or craftsperson (if perferred).
However, a contest would require that an automated process would require a category be created for it and hand made pyro a separate category. It wouldn't be fair to the automated process to have to compete with the hand done because the automated process would loss everytime.Just my opinion and nothing more.
Don
***Laser pens allowed
Two of the three judges have agreed to allow hand-held laser pens in the Turning & Burning contest, so it's a majority. The third, Graeme Priddle, has not yet responded, but I'm pretty sure he'll be in agreement also.
You're good to go.
Now I Have To Make One, Then . . .
charlie belden
learn how to use it on flat stuff,
turn pieces to get practice on curved stuff ,
come up with a pyro design idea,
use the laser pen to do the design on a REAL piece,
(recuperate from a laser accident?)
figure out how to take good pictures of probably some subtle details,
come up with a title for the piece,
do a write up about the piece,
submit the photos of, and the text for, the piece,
- and pay the entry fee,
by September 30th?
90 days should be more than enough time ; D
(in the background
Ex Wife 2 is yelling "Where's my A&C book case and end table - you promised to make for me - last Christmas!?"
Little Voice In My Head 1 is asking "So I'm not going to get to play with the laser engraver much?"
Little Voice In My Head 2 is asking "Why'd I FINALLY get the electronics stuff to incorporate lights, sound and movement in a piece -- under micro computer control - and then not have time to play with ideas that have been in the queue for a year?
Great. Just GREAT! )
Ray - Middletown, IN
I think I remember reading that the laser in a DVD burner is strong enough to burn wood, also the one in a blu-ray player. Not sure I want to spend the bucks for a blu-ray and then tear it apart just for the laser but I'm sure someone will eventually. Ought to be able to find a used DVD burner easy enough. To be really effective I would think a variable power or variable focal point would be desirable. You would need to go from a fine line "hard" burn to a wide "soft" burn for variable shading. A scroll wheel under your finger would be ideal. Having said all of this, the dangers involving the eyes are really significant. The liability to the user and manufacturer would make any insurance company cringe.
Ray
Re: What controversy?
Russ Fairfield
Just do it and quit talking about it. Why does there have to be a controversy?? It's a woodburning tool, the only difference between a hand-held laser and a hot wire is the source of the heat. I doubt that anyone will know the difference on the finished product if the piece is well done and shows some skill in burning wood.
Only another woodturner will ask how it was done. Everyone else will just look at it, and they will admire it if it done well.
charlie belden
Not sure where this idea of "a need for validation" is coming from.
I do things that interest me, because they're interesting and seem like they'd be fun to try. If I find something I think might be of interest to others I put what I've found - and one way to do it - out where others ,who might be looking for something interesting to try, may see it. And if someone plays with one of these ideas and maybe needs some help - I'm up for that too. I'd hope that if they then discovered something interesting, they'd share what they've found - and I might give it a try.
Others may have a very different approach to life.
charlie belden
Not sure where controversy entered this one.
If I'm doing pieces for myself I can, and do, whatever strikes my fancy, anyway I can come up to get where I want to go. If the piece is for someone specific they define much of the WHAT, but HOW is still my call. But if the piece is done as an entry to a contest - and the contest has rules for qualifying to enter the contest - and I want to use a technique or tool that's different from the usual ways of doing things - it seems prudent to ask if it DOES qualify for entry to the contest - before going ape creating a piece only to find out it violates the contest's rules and therefore is disqualified.
So, seeking clarification of the rules I provided a link to a video of the type of tool I was considering using which showed the tool in action - burning wood. With that information, the judges have a good idea of the thing of which I'm requesting clarification since the written rules are ambiguous. I've got another "tool" I'd rather play with - but there's no deadline for that one. This contest does have a deadline. If the use of a handheld laser pyro tool wouldn't qualify for the contest, I'd rather not spend time on an entry.
I now know that a pyroed entry done using a handheld laser pyro tool does qualify for entry - to this specific contest. Now I've got to decide if I want to spend the time on an entry. Probably will - just because it seems like it'd be fun and interesting.
Where to get the laser?
Colin
Coming back to my original question has anyone found a source for the laser used in the video? eBay doesn't seem to have anything like it. I would like to give one a go as I have not had a lot of success with a conventional woodburner.
Re: Where to get the laser? *LINK*
charlie belden
There's a boatload of YouTube vids and one you may want to watch is "ebay green lse pointers tutorial -- scam exposed. Like woodworking machine manufacturers, who advertise a 5 HP compressor - that'll run on a 110V 20amp outlet, POWER is often exaggerated or misleading at best.
From what I've found, modifying a low powered laser pointer from 5 or 10 milliwatts up to 100 mW where it can start to burn stuff typically kills the laser pretty quick. The laser in a CD burner starts out with more power and old CD burners can be had for a song. You may have one in an older computer. But for some REAL power - a DVD burner's laser has the OOOOOOMPH to burn wood from the get go. The tricky part involves keeping your hands away from the laser which generates a bit of heat. Fiber Optic "wire" will let you separate the laser's heat from the end you want to hold and work with.
Making a hand held laser "pyro system" ain't quite as straight foreward or as easy as I initially thought. Looks like it can be done - but it ain't gonna be inexpensive - you pay up front with Dollars, or pay in Time and Effort. If you've got the time and the interest to pursue making one - PLEASE keep us posted.
Might start here
