Veritas - Innovation in Tools
Marco Polo's Treasures
Bill Clark
I haven�t posted in a while but have been working on some new pieces. When I finally worked out all of the new designs and colors and turned the pieces, the weather was too cold to airbrush the colored beads and handles. Finally, when spring arrived, I was able to complete this set, which is a refined progression of my calabash and oriental-themed previous work.
As with my prior pieces, this set is graduated. The tallest vessel (6 1/2�) has the smallest diameter lid (4�). The shortest vessel (4�) has the largest diameter lid (5�). The handles are also scaled in size. Each piece is branded with a tip of my own design. The colored rings, lids and handle tops are impact compression textured. The branded areas are finished with black gesso and then sprayed with a matte finish. The textured rings, lids and handle tops are finished with various metallic artist colors, which throws off a nice iridescent metal look. The beaded rings and handle bases are airbrushed with a custom color blend. It took me a while to find the right combination that pulled the metallic and black colors together. The wood is big leaf maple. The vessel sides are just over 1/8� thick. The insides of each piece and lid are finely sanded and finished in the natural color.
I have often wondered what Marco Polo brought back from his journeys to show the western world. I imagine his selections would have been of both a practical and Oriental nature. These are the qualities I was striving to attain with this set entitled �Marco Polo�s Treasures.� All comments and critiques are welcome.
Re: Marco Polo's Treasures
Lance Kanaby
I am truly impressed! These are wonderful turnings and they really sets the bar a whole lot higher for me and I am sure many more of us.
Very nice set!
david
Indeed these can be considered treasures...
Keith T
These are wonderful! It doesn't get much better than this.
Philip Duffy
Stunning work, Bill. Thanks for sharing your wonderful accomplishment. Phil
Mike Rubes, Apex, NC
Hi Bill,
Those are simply wonderful! I love the surface treatment of them. You are not even sure they are wood, or ceramic, or metal or what until you open them and see the woodgrain inside.
I love the blueish/black color combo. They are stunning pieces.
Thanks for the pics.
Mike
Seeing the bar raised higher and higher in Apex, NC!
Deeelicious Bill!!
Molly Winton
Bill Clark
Thanks Lance. I've been branding for 3 years now. It's been a slow process to perfect the procedure and find designs that I could incorporate branding into my work. I've been told by the pro's to do the same thing over and over because each time you make refinements and subtle changes. That certainly has worked for me. Each piece gets a little better.
Thanks Everyone
Bill Clark
Thanks for commenting David, Keith and Philip. Your comments are appreciated. I'm a member of a small turning club so my exposure is really limited to the internet. Having other turners acknowledge my work is encouraging.
These are outstanding.  Nice work!
Craig Daymon
Thanks Mike
Bill Clark
Thanks for commenting Mike. The colors I used are the result of many hours of testing, including changing brands of airbrush paints for the beads and handles, and mixing colors. The metallic colors are actually on a black gesso base with 1 solid and 4 metallic colors added one at a time which resulted in finish where all of the metallic colors are evident. The amount of each color and sequence of application is determined by the dominant color I want. Then the beaded ring and handle color is mixed and airbrushed on to hopefully tie the metallic and black branding together.
Thanks Molly!
Bill Clark
Thanks Molly. My exposure to branding at your AAW demo in Portland got all this started. I'm taking these to Hartford in June so you can see them in-person there.
Bill Those are really outstanding. I saw them on WoW but didn't comment. Not sure why because I really liked them.
Thanks John!
Bill Clark
Thanks John. I've been a fan of your work for sometime and always enjoy your contributions to the forums. I'll be at Hartford and hope to meet you while there.
Wonderful
Mike Foster
A perfect set of containers. I love the textures and metallic highlights. The varying proportions lend an added delight for the eye, yet the set remains a cohesive whole. Great work Bill.
Mike
Re: Wonderful
Bill Clark
Thanks for the kind comments Mike. The metallic colors were a challenge. I did many combinations and different sequences before I finally got what I wanted. Fortunately I kept good notes and test pieces so I won't have to go through that again.
Leo Cuellar
Leo Cuellar
I've been lurking on the site for a while now. Recently got the nerve to join.
The "Treasures" truly are! Awesome work!
Bill Clark
Thanks for the comments Leo and welcome to WoodCentral. This a great place to get woodturning advice, info and inspiration.
Chris Hoehle
Outstanding set! I love the color and textures. I've bookmarked this post for future inspiration / reference. Do you have any book recommendations for getting started with airbrushing?
Bill Clark
Chris, Thanks for the nice comments. In regards to airbrushing books I haven't found anything that helps me with the type of spraying do. Basically I'm just spraying on a mixed color without trying to shade or create a picture as a true airbrush artist would do. I plan to move into shading my pieces in the future but haven't tried that yet. An airbrush does a wonderful job of laying down a forgiving coat of paint in a small area which is what I need for this typing of work. I do have two recommendations that may help you. I use a Grex airbrush and they have the best getting started DVD I've seen. It covers the basic spraying techniques and cleaning. You might try and get a copy from them. Second I attended 2 demos by David Nittmann at the last AAW Symposium. He has a lot of info and may be able to give you some book ideas. Check out his web page at www.davidnittmann.com.
Binh Pho also has a great DVD on Airbrushing
Re: Binh Pho also has a great DVD on Airbrushing
Chris Hoehle
Thanks for the tips on airbrush resources, Bill and John. It's definitely on my list of things to do at some point. Though the list is getting pretty long - yesterday I just picked up some black gesso and A/B bleach to start playing around with black and white pieces and got some copper paint & verdigris solution to try out as well. So, it might be a while before I get ready to do some airbrushing :D
