Not sure if I posted this here before?
steven antonucci
Cherry vessel, carved and gessoed.
About 6"x4".
Steve
steven antonucci
About 6"x4".
Steve
Re: Not sure if I posted this here before?
fgvanatta
Well, I certainly haven't seen it before. Excellent design. I like it.
Frank
Ron Lynch
That's very cool, at first glance I saw mosaic tiles.
Way cool! How about some detail photos?
david
Closer look
steven antonucci
This piece of wood was touched by my hands probably 10 times on every surface. Cut, sand, sand some more, carve, sand, gesso black, sand, gesso white, gesso color, sand, wax, buff...
S
charlie belden
After reading the description of your process and looking at the detail shot I'm thinking about cloissoine (sp?) where rectangular or round wires are attached to an underlying surface to create "cells" which are then filled with different colors of ground glass that's later melted to create glass enamel. The "cell walls" keep the colors from blending together when the ground glass is melted.
The cells are packed slightly higher than the "cell walls" - mounded towards their middles - because when the ground glass melts its volume shrinks. Once the glass is cooled the glass ABOVE the wall is ground down flush with the top of the walls and polished. The result is enamel patterns of individual areas of color that are separated from adjacent colors by metal.
To "cloissoine" a turned wood piece the wires could be epoxied onto a surface and polyclay - or whatever - could be packed into cells, baked and then turned flush with the tops of the cell wall. If the area to be cloissoined were turned slightly low, to accomodate the wires height, the final surface could be turned so everything is flush - one surface.
Another approach to get a similar effect is to extrude the polyclay through something like a honeycomb, the cells packed with different colors of poly clay to create the pattern - analogous to needle point. Thin slices of the resulting "extruded pattern" could be cut off and applied to the wood, baked and then return the whole piece to level the surface.
Hmmm . . . V E R R R R R Y I N T E R R R R R E S T I N G.
Way ahead of you...:-)
steven antonucci
Both of my older kids play with polymer clay. I have some notes scribbled for such a project already as a way of doing a collaboration with the kids, and another such project with the wife (who scrapbooks (easy) and sews sock monkeys (not so easy) to collaborate with...)
The next one of these will have some additional effects. I just put this piece at Peters Valley for the instructors show that runs for the summer session. I had intended to bring it to Hartford, but only so many places I can be at once...
Now glass on wood sounds interesting... If I could only get my forge to melt glass (oh, yeah, BTDT...:-)
steve
