Robust tool rest
Robust tool rest
Dick Hines
Robust tool rest
Dick Hines
Woodcraft , at least the one in Richmond, is not selling the Robust tool rests. I have had the 4" one for a while and not I have a 12" one. Love them.
Re: Robust tool rest
ted evans
I have the 4 & 6" and agree with you on the quality, I am saving my lunch money for the 12".
What's the steel they use?
I made a drill-rod insert for my Poolewood rest, but I used O-1 drill rod and didn't harden it. It now has dings in it. I was wondering what the state-o'-the-art rests might be made of?
Re: What's the steel they use?
Ellis I don't know but I've used mine hard for the last 2 years and no dings at all.
Carole Valentine
Yep, I have had two for a while. Love them both.
Don Geiger
Don Geiger
I have several Robust tool rests and am very happy with them. Since I do demonstrations on lathes other than my own, I have an additional ones with a longer posts so I can work on lathes with larger swings.
I like the Robust tool rests for the following reasons
1) The hardened rod along the edge does not get nicks in it and my
tools traverse the edge more smoothly and with less effort.
2) The narrow width of the edge allows me to establish a fulcrum point
very close to the wood. Some of the cuts I make with my side-ground
bowl gouges require me to drop the handle way down. Because the
edge of the tool rest is narrow, the fulcrum point is still very
close to the wood. With other tool rests that are much thicker- this
isn't the case.
3) The curved support gives me a place to safely and comfortably rest
the meat of my hand. With my hand against this area I have better
control of my tools. Most tool rest designers forget the inmportance
of having a place for your hand.
4) The curvature of the support places the top edge off-center from
the post and puts it close to the wood. This keep the banjo out of
the way of the spinning wood.
5) The Robust rests are made in the USA.
6) Brent English, owner of Robust, is a great person and a hard-
working and innovative American.
See the Robust web site at: www.turnrobust.com
Don Geiger
I have no afilliation with Robust.
Cyril Griesbach
I can't heap enough praise for my Robust tool rests.
Amen Don!
Molly Winton
I've got Robust tool rests for my Woodfast, 1224, and Jet mini. Love them all! In my opinion they're the best tool rests on the market. I agree also about Brent and Deb. They're terrific!
Rich Egan
Yep, I like mine too. I just wish I had the lathe that goes with them!
HeatherAinAK
Do you all use/like the standard or low profile models?
Heather
I like the low profile but then most of my work is small and I often wrap my fingers around the rest. If was turning larger work I'd go with the bigger rest.
E Tabachek
I have Robust rests for my maxi with the 5/8" post. I like to use them. Very nice.
I bought 2 rests with a 1" post for my Woodfast and General lathes, but the posts are just a little too fat to slide into the banjos. Tool rests from the Woodfast, General and even a Graduate are all inerchangeable in each others banjos, so I conclude that the Robust post is too fat by a smidgen. I am not sure how to remove the very small amount of steel so that the tool rests fit into the banjos. Maybe a cloth backed abrasive wrapped around the post and worked by hand ?? Or maybe one of those mylar micron abasive belts in a belt sander worke freehand ?? I don't want to take off too much but I don't want to spend months doing this.
What do you think ??
Edward
Molly Winton
You might want to contact Brett. I'm sure he'd be able to help you out. Course, I might try the cloth-back sandpaper first, if it were me.
Metric
Edward, your Aussie banjos are bored for 25mm whereas your Robust post is 1"; a tad larger than 25mm.
There are several remedies:
a. buy yourself a 1" drill and carefully redrill your banjo's post to 1". :\
b. take your banjo to a local machine shop and have them do it. :)
c. go to an auto parts store and buy a brake cylinder hone that will fit into a .90" bore, hook up your power drill, and regrind your banjo's bore until it accepts the 1" shaft. :b
d. buy a hand reamer that will take your 25mm bore to a full 1". >(
htrh
I Fixed It
E Tabachek
Thanks for your helpful suggestions. 5 minutes with a piece of 180 grit tape wrapped around the post has done the job. The Robust posts now side into the Woodfast and General banjos easier than with an application of Cialis and Astroglide.
I spent more time looking for the abrasive tape than the job took.
Happy with my tools !!!
ET
HeatherAinAK
Does anyone make adapters so you can use the 5/8" tool rests on a bigger lathe that takes a 1" post? I would love to buy one that I could use on my jet mini and on my powermatic. I would think that you might not want to do this with big tool rests and heavy work but it seems it would be OK for small things.
Heather
Dale Bright
Penn State makes an adapter that will make a 5/8 post fit in a Powermatic banjo.
Heather Although a tool rest adaptor would allow you to use them in both banjo's I would think the length of the post would be wrong. Mini lathes have a much shorter post than the larger lathes unless they both happen to have the same swing.
The other option would be to get the Bestwoodtools or Woodcraft tool rests that take different posts. Of course I bought 2 posts for my bestwoodtools tool rest but I never change it so it was a waste of money for me.
HeatherAinAK
John, I was thinking it would only need to be a sleeve of 1" piece of steel or whatever that was the same length as the bigger tool rest posts. It would just need a 5/8" hole the same length or a little less than the small tool post. A set screw and your done. Think it would work?
Heather
If the 1" post was long enough to allow the tool rest to sit where it should then it would work. I'm guessing theirs are bored all the way through for 5/8". It looks like theirs has a slot for the screw from the banjo to go in but that would assume that the screw on your banjo is long enough to lock the 5/8 post in place.
your idea of a setscrew in the 1" piece would work if the setscrew was high enough that it never went in the 1" banjo hole.
Re: Robust tool rest *LINK*
George Van Beynen
Heather, I did as you are planning on my Oneway 2436. The outboard toolrest has a 1 �� tool post. I bought 1.5� OD x 1� ID DOM (drawn over mandrel) steel pipe which is very close to actual dimensions. I can now use my 1� toolrest on the 1.5� banjo.
DOM Steel Pipe
Thanks
HeatherAinAK
Thanks John, I think this might work.
Heather
HeatherAinAK
Thanks, I saved that link, it looks like just what I need.
Heather
