vacuum chuck repair
vacuum chuck repair
vacuum chuck repair
I was turning a bowl last night and heard what sounded like an air leak. I stopped the lathe immediately. I noticed it had dropped from about 20" to 10" on the gauge. I could hear what sounded like a tire leaking. I shut off the vacuum and removed the bowl. The gasket material had come loose. I don't know what glue I used to glue this on but it had come loose in about 3 areas.
I checked the other chucks and all had loose gaskets. I reglued them with contact cement. I checked them all and now have 27" of mercury on each.
Moral, when you hear a strange sound, stop and investigate.
Re: vacuum chuck repair
Don Geiger
Don Geiger
Hi John:
Glad you caught it before your work piece flew off!
You may be aware there are vacuum switches that actuate either normally open (N.O.) or normally closed (N.C.) electrical contacts. Some allow you to set the minimum vacuum for the switch to activate. With a device like this, you could have it hooked to a light or an audible alarm to warn you when you've lost vacuum. I've heard of them used when vacuum pressing veneer to control the pump to come on and of as necessary to maintaing a specific range of vacuum and so the pump doesn't have to run continuously. I have a diagram on one slide in my C-D that shows one that would activate a light.
I've seen these swithces in one of the supply house catalogs like Grainger or M&C or McMaster-Carr. I'll look around to see what I can find. I'll let you know.
Don
Bill Hale The Wood Spinner
Glad you are safe. I always work in a quiet shop, no radio. I also teach students that part of turning is listening to the wood.
