Potentially useless new scientific discovery
Steven Antonucci
steven antonucci
New to me at least.
I bought some of those super magnets for my lathe today to stick tools to it. These are 1" circles that will draw blood in a pinch situation. They are super strong.
I was using the lathe to hold a work piece in the chuck while painting it with black gesso. I had a small plate with the gesso in it, and I placed it on top of the headstock where the magnets were.
It stuck.
Did you know that black gesso is magnetically attractive? Me neither, but it is a very strong pull, so I can only assume that the black is due to iron content.
Now, I am off to test other color gesso...
I warned you it was potentially useless...
Steve
Re: Potentially useless new scientific discovery
Mike Stafford
Mike Stafford
Who knows what scientific advances may come as a result of this amazing discovery?
It may be just what is needed to solve the problems with fusion energy generation.....
Of course, it may be useless also...
RInteresting-and maybe useful
charlie belden
Until somebody tried it - no one thought to use a vacuum to hold a piece to the head stock in order to do turning that wasn't possible, or far more difficult, to do.
If the magnetic force is equal to, or greater than, the 14.7 psi a "vacuum chuck" provides you may have stumbled on something that will replace vacuum chuck systems - for a LOT less money - and hassle - with NO compressor or vacuum pump noise.
You wouldn't have to rely on magnetic material in gesso or some other applied material. Put cork or some other compressible, non-marring magnets - on on a chuck or face plate, one inside the piece, the non-marring material providing some cushioning and protecting the wood. Would also keep the two magnets from slipping apart.
Assuming you can get Limitied Liability Insurance - this might be a mini-gold mine - until word gets out ; )
(I've been playing with ideas for magnets - in repel mode. They also have an attract mode? Who'd thunk THAT?)
Steven Antonucci
Laws of magnetism
steven antonucci
Do not put your fingers in between two very strong magnets.
Do not put very strong magnets near your TV.
Do not use these magnets to pick up filings, or they will never come off...(I wrap them in plastic bags first)
Oh, yeah, they push and pull pretty good...
S
Laws of magnetism No.5
Scott Burr in Ben Lomond CA
Don't let them hold tools. Otherwise you will have to use Law No.4 every time you sharpen them...
DAMHIKT :(
JB Weld, too
In modifying a steel fence staple driver I drilled a hole and glued in a supermagnet with JB Weld. After applying the glue, I watched as the epoxy magically flowed up out of the hole and globbed up on the top of the magnet. I had to repeatedly push the epoxy back down into the hole until it started to set up enough to stay.
For more fun, we used to mix powdered iron with a thick oil. This makes a fluid that becomes quite viscous (nearly solid) when in a magnetic field, then turns liquid again when the magnet is taken away. When viscous, it will retain the shape you give it. I think this is called a magnetorheological fluid.
Also, there is a black paint you can buy in the borg that can be applied as an undercoat to allow magnets to stick to any surface. A friend used it under sections of her boys' bedroom walls so they could put up magnetic letters and stick up pictures and things with magnets.
Re: JB Weld, too
John Jordan
You can separate Canadian coins from US. The Canadian coins will stick to the magnet. :)
John
Dick Hines
Re: Laws of magnetism No.5
Dick Hines
A friend of mine was talking about useing rare-earth magnets to hold the tops on some pieces he was turning. He was telling me how strong they were. I told him he need to try turning the magnets so the poles matcher up (+_+ or -_-" and see if he could make a box with a floating lid.
This would be a good one for Charlie to try.
Sounds like magnetite
Mike Brazeau
On the beach at our cottage on Lake Erie, sometimes there is a layer of magnetite sand up to an inch thick. I have gathered some up to use for filling voids with epoxy but never get around to cleaning it up to get rid of the small amount of sand. It is finer than sand and a complex form of iron oxide which is black in colour. We picked up a couple of cow magnets for grand kids to play with with the stuff.
Tape works -
Dave Belser
I use a lot of magnets and have found that it is easy to remove filings or other small bits of stuff using the sticky side of plain old masking tape. Pull as much off as you can with your fingers and use the tape for the rest. Works like a charm.
It's a scale thing, the little bits really want to stick to the tape rather than the magnet.
charlie belden
David Besler used small magnets to hold the top on one of his spherical lidded boxes made up of thin bamboo skewers. The piece I saw was the back cover of the latest American Woodturner magazine from AAW. By twisting the lid, while holding the box still, the magnets can be moved sideways, breaking their magnetic grip.
I did pursue a MagLev idea for a floating hollow form - magnets with the same poles facing each other - in a hollowed out area in the bottom of the HF and a separate base plate the HF sits on. As others pointed out when I floated the idea, the HF does "levitate" - but unless its movement is constrained to the vertical axis and rotation about the vertical axis - it's very unstable. Still working on ways to constrain the movement while still permitting movement only to the vertical axis.
Wonder how magnetized spheres - like ball bearings behave? Make a lidded box - with a central vertical shaft from which horizontal spokes radiate towards the inside wall. Small rare earth magnets glued to the ends of the spokes might hold ball bearings in "races" turned in the outside of the box in place. When the central shaft was rotated the ball bearings might move around the outside of the piece.
Hmmmmm . . .
Dave Belser
Actually Charlie the piece on the back of the last journal used bamboo pins (6 sets of 2 each) in the voids around the perimeter of the sphere. I use magnets to hold another bamboo sphere together - that one was posted on WOW. Both are on my website davidbelser.com
I first saw magnets used to hold a box together at the Louisville symposium, someone had used them on a tetrahedral box.
I've got an idea for a box with a lid that pops off via magnetic repulsion but it's a lot of work to figure out the kinks.
As for a levitated peice here is an idea - two spherical sections, the bottom one significantly bigger than the top is like a bowl. Use a *LOT* of the tiny magnets on/in the surface of the bottom one. Put opposing magnets on the bottom of the upper sphere section, again use a lot of them. I'm thinking 500 hundred+ on the bottom and the same density on the upper shell. Weight the upper part so that it wants to stay upright and not flip over.
I bet it could be stable as long as it didn't get to close to the edge of the bottom "bowl". Is it worth trying? don't know. But it would be really cool if you had large 15' bottom and the floating section was big enough to stand on!
Russ Fairfield
Steve, you said. "Do not put your fingers in between two very strong magnets."
Why not??
Steven Antonucci
They pinch
steven antonucci
The pull on these little discs is something like 50# each, so they pull with a lot of attractive force. It isn't so bad if you have your whole finger, but if they slide to the side, they can pinch enough to break the skin. DAMHIKT...
Here is a picture of two 1" x1/8" discs separated by the thickness of my hand. (roughly 1.5")
The pull is so hard that the lower magnet sticks through my hand. I forget my Electricity and Magnetism Coursework from 25 years ago, but I can tell you that the magnetic attraction is a function of distance. As they get closer, they pull much much harder- and they move towards each other very quickly. These are not your average magnets.
I like to have a bunch of them stuck to my lathe to hold allen keys and chuck keys. These replaced the 1/2"x1/8" ones that I used to use. They work 4x better. Last night, just for giggles, I stuck a no. 5 Stanley plane to the side of my lathe, and it held...
I make turned wooden fridge magnets out of the little one. They hold a lot of stuff on the fridge...
steve
Check this puppy out *LINK*
Dave Belser
1000 lbs+ of force in a 4" disk 2" thick.
"They are freakishly powerful and should only be purchased by users familiar with the proper handling of very large neodymium magnets. Two of these stuck together are impossible to separate by hand.
It is recommended that they be handled with the assistance of at least one other person. As with any rare-earth magnet of this size, they can pinch, crush, or otherwise cause extreme physical harm if they are not handled with the greatest of care and respect."
A serious concern is children or animals ingesting the 2 or more of the small magnets. They can end up on opposite sides of intestines but stuck to each other.
http://www.kjmagnetics.com/proddetail.asp?prod=DZX0Y0-N52
Steven Antonucci
You wouldn't get the tool off the toolrest
steven antonucci
That's the mac-daddy of magnets
great text, worth reading.
Steve
Don Geiger
Don Geiger
I'm not at all surprized. I've worked in the scientific industry for many years and "yes" metals are commonly used in paints either as pigments or for other properties such as durability, flexibility etc.
I was selling and X-Ray Fluorescence (XRF) machine for several years that was used for many puposes, but one was to determine if paints had lead in them (remember the concern of lead in children's toys- we even found it in candy!!). XRF analyses revealed many metals(it responded to 26 elements) in paints.
XRF is a facinating field. The fun part was experiencing all the different applications they are successfully used for. It got me into NASA, USAF, US Navy, fossil and coal fired power plants, turbine engine manufacturing and repair facilities and many scrap yards (the really fun stuff!) forensic labs and museums etc.
Don Geiger
Re: Check this puppy out
Dave They had 6 or 8 of these lined up trying to deflect a bullet on Mythbusters. I pinched a blood blister on my hand with one of the quarter size magnets. There isn't any way I want to mess with one that size.
Re: Maglev possibility?
Bob Macgregor
On that web link, I noticed some axially magnetized items. That sounds like what Charlie needs for his magnetic suspension idea...though the ones pictures didn't have a very large diameter.
BOB
>...Steve, you said. "Do not put your fingers in between
>two very strong magnets. Why not??
He should have said don't let your fingers get pinched between two strong magnets as they are slamming together. Can be painful at minimum.
I have a couple of 2" diameter magnets about 1/2" thick. They are so strong you will not pull them apart if allowed to come in contact. If they are allowed to slam together with a finger between, I am certain there will be significant trauma and loss of blood, perhaps a broken bone.
One thing to watch - if even smaller super magnets are allowed to slam together, they will likely chip or shatter. Years ago we would cover them with either tape or shrink-wrap tubing for protection.
