trying something new *LINK*
joazhill
In order to relieve some of the bordom of going round and round, I am now trying something new. This piece has been burned with a heated router bit and an old modified skew. I also recieved a Fordom carving rig for Xmas that I have been playing with with more photo's coming. This new approach is inspired by the work I see on this board. I am also trying to get out of this deep rut I am in after turning the same old thing for the last 18 years.
This is maple 14x5.
Commets welcome.
Joaz
ShapeShifter Woodturning
Re: trying something new *LINK*
Jeff Morneault in northern Maine
Nice job Joaz! The pyrography definately adds to the piece without being distracting.
Bill Neddow
This piece is beautiful, Joaz. Keep them coming.
Nice work!
Jorge Casta�eda
Re: Nice work!
fgvanatta
Unusual and beautiful bowl. Great idea with the router bit.
Frank
david
You've got at least 10 years on me, so who am I to offer a suggestion, but perhaps what you should look into is turning wood that is not boring. As John Jordan is quoted as saying: Life is too short to turn junk wood.
Steve Kubien
Steve Kubien
Very nice. Burning can become a serious addiction. I got my Eagle about a month ago and now I look at every piece of wood and say, "But it is too pretty to burn!"
Have fun.
Very nice- restrained which works well.
charlie belden
OK - I think the "S" pattern was done with the end of a heated small spiral router bit and the long thin triangles were done with the side of the long point of a small heated skew? An innovative idea used to create an interesting pattern on a nice bowl.
Never occured to me that tools for cutting wood could also be used to burn in a pattern in wood. Another interesting idea that once you see it you slap yourself on the forehead and go DUH! With ideas like this, and ideas the flex shaft will likely present I think your rut is over.
Now if you have a half round coving bit in your router bit collection - chuck it up in a jacobs chuck in the tail stock and use it to make the "socket" of a ball and socket joint. I'm assuming you can turn the "ball" part on the end of a piece. If this doesn't make any sense to you - try the stuff at the attached link.
If you're bored with round - why not try multi-axis turning/ THAT may keep you away from ruts.
Ball & Socket/Swivel Joint
Terry Scott
Like were this is heading must have been a slow process heating the router bit each time
very nice job
Cheers
Looking Good !
Don Orr
Steven Antonucci
I've been playing with this idea too
steven antonucci
Except I forge my shapes in my little coal forge first and then brand them into the wood. Still working out the kinks.
Can I assume that you branded, then cut the bead back to get such a clean line without any flash over?
Steve
Re: I've been playing with this idea too
joazhill
Hi Steve, actually, I cut the bead first and then very carefully branded. I guess I was lucky and did not mess up to badly. I have had a few failures on other pieces where I had to return to the lathe and remove the entire branded part and start over. I get wood that has already been cored, so I leave the piece thick allowing for any major burning mistake and only turn the inside when all is finished on the outside. Kind of scary when you have put all the time and effort on the outside or rim.
All the brands are heated with propane torch. Very tedious.
