Does It Matter HOW?
charlie belden
I'm playing with a laser engraver as a pyrograph tool. Like any other pyrograph tool, be it branding, vaporizing, scorching or selectively burning, it burns wood. The only real difference is how much more control you have over how much it burns, where it burns and how fine the details it burns ( resolution).
What is different about laser engraving (or carving) is that the actual burning process is not interactive, but controlled by the laser engraving device based on the information YOU provide it. The creation of THAT information IS interactive and is much like any other type of 2D artwork creation. The tools and techniques are different because YOU use a computer, a computer input device like a keyboard, a mouse or a pen and tablet and a computer graphics software application. What IS different is the ability to
- UNDO mistakes and quickly recover from an OOOOOPS
- manipulate the artwork, or elements of the artwork (scale, rotate, reposition, etc.)
- quickly do variations of a "drawing" - without affecting the original - by working with copies
Having just gone through 30 video tutorials on just one of the computer graphics applications (Corel DRAW 12), my mind is reeling at the possibilities.
If you've attended a Bob Rosand demo or seen one of his "written on" pieces - imagine creating a path for the text to follow then giving the program the text you want to follow that path. CLICK - and the text wraps along the path. Hide or don't "print" the path and you get JUST the words - following the unseen path line. The path can be a square, circle, oval, concentric squares, ovals or circles - or any other path you create.
Artists have been using shading to give he illusion of 3D for a long time. But shading with pyrograph pens is tricky and not very refined. With a graphic application, shading is fairly easy, as are gradients. And for the most part, you're playing with WYSIWYG (What You See Is What You Get - Wis See Wig).
Then there are the actual Low Relief 3D "carving" possibilities which is what I'm really interested in and will be exploring. The information in the Gray Scale image you feed to the laser engraver tells the laser software WHERE to burn - AND - how DEEP to burn - in VERY small, very precise increments (0.003") - a control phreak's nirvana.
Like any other tool, be it a turning gouge or a pyrographic pen system, there's a learning curve to climb to get good at using a graphic application and a laser engraver to get the results you're after. In that respect, using this newer technology is no different from using earlier technologies, be they new steels, new grinds, carbide tips, hollowing systems. sand blasters, etc..
Other than reducing The Element Of Risk associated with other methods of getting to the end result - Does It Matter HOW - you get to the end result?
What say you (and please expand on your Yes or No answer if you would)?
Sooner or later someone will look at what you are doing and take it to Asia. Then what is left for you?
