anyone have ideas for portable display pedestals?
-e-
they need to knock-down flat for transporting and storing.
light-weight would be helpful.
any suggestions are welcomed?
thanks
e
-e-
thanks
e
Re: anyone have ideas for portable display pedesta
Dick Hines
2X4's make good stands. I use them in 2",3", and 1". Paint them balck. I cut them square. They work good to lift a piece off the shelf and don't distract from the piece.
Rather than knock down flat I have a friend who stores hers inside each other. She has both square and round and they stack in layers of 3. The square ones are MDF. Her new ones are covered in Formica but the old ones were just painted and she just carried some paint with her to touch them up when they get scratched.
I think the round ones are purchased from a source that sells round wooden tubes. I think each one is about 1" smaller than the next size so they fit inside each other very nicely for storage.
She has seperate tops that fit on with magnets. This allows her to change the top sizes easily and it's also easier to store.
I'm going to a craft show next weekend to do some booth photos for friends. I'll try to look around at what people are using for pedestals.
Keith T
Hi -e-, I use sonotubes, normally used to create concrete forms. They fit inside each other, and sprayed with texture paint and applied lid, look pretty good.
Sono Tubes from Lowes
Jennifer Indy.USA
E- I have used Sono tubes that I bought from Lowes. I cut a piece of 1x3 the inside diameter fo the tube and rounded the ends so they just fit inside the bottom then screwed them in place. I then would place a 1 gallon ziploc bag filled with sand on top of this cross piece for stability. For the tops I would use a piece of 2'x2' ceramic tile from Lowes. I cut another piece of wood this time 2x4 in the same fashion as I did the bottom. Curved the ends on the bandsaw so that it fit just inside the top rim and I glued this piece to the bottom of the tile so it would keep it centered and would not be bumped by passers by and knock off center. I painted mine and as they got scratched up in transport I'd just touch them up. When you buy them you can often find them stacked inside each other. I bought two sets stacked so I knew I'd be able to do this for ease of transport. Just mark the inside with a number system so you know how they go back together. I did use a jigsaw to cut them to different heights to make a more interesting display. They are a bit more space using than some other methods for display but I liked the clean lines and look of them.
Jen
Brian George
Besides the concrete tubes, I use collapsible shelving from Shopko. The shelving folds down flat and into a box that is less than 5 inches high and easy to load into a trunk or suv.
For a couple years I used glass blocks with the paint removed and holes drilled in them to stuff in white Christmas tree lights. They are toooo heavy to carry around and required boards for the shelves, plus they required electricity, which is not always available. The collapsible shelving seems to be the cats meow - so far!
I used this idea too :-)
steven antonucci
My daughter's theather group asked me to make three small stools (a week before a production..."Hey, Steve's handy!"). I needed something cheap, strong, and that would look good enough unless you were right on top of it.)
I took the sono tube (48" tall) and cut them down on my tablesaw (against a fence, just rotating through the blade) and then used a router with a trammel arm to make round end caps. Painting was a pain because the lettering was visable through the black.
There were times that 2-3 kids were sitting on them, and I sat on them too. A sandbag at the bottom sounds like a great idea...
Steve
jim miles - Charlote NC
I use a 4 sided "box" of light weight paneling or plywood with top that sits on it. Piano type hinges on side - they fold down flat.
It has a styrofoam square glued to the inside of the top to hold it in place, Came up with this after a couple heavy versions that took too much to set up. Also have seen Sono tubes - they can be used to store and move stock in.
Dick Hines
I thought you were just looking for something to rase your work off a shelf. Did not understand you wanted a stand.
NEVER MIND!
John Jordan
Easy- 12 x 12 x 48 cardboard boxes. Tablesaw some to different lengths(height). Use two pieces of 1/2 mdf for the tops, the lower piece fits just inside the box and holds it square, the top over laps just a little. Transport/store them folded flat, wait until you get where you are going, and roll on a coat of latex paint.
Light, cheap, small, and they'll last a long time if you protect them. And they'll look good as anything.
John
Thank you, ALL! for such wonderful suggestions
-e-
