Band saw question
Band saw question
Roger in MO
Band saw question
Roger in MO
I recently purchased a used Delta 28-262 band saw, 14" with riser block.
Quite a bit of fine dust comes up on the left side around the U shape blade protecter. The blade is carrying the saw dust or at least the air movement caused by the moving blade.
Is this normal for this saw? Is there a way to minimize it?
Thanks
Roger
Re: Band saw question
Yes and Yes
I have a Delta saw also. Mine had a little volcano of dust coming up off the blade on the return side. There are a couple of things you can do. Install the brushes that clean the wheels and Install Dust collection. Delta makes or used to make a dust collection port for the saws that mounts under the table on the right side where the blade goes down through the table. I made one for my saw out of and "end boot" for 4" ductwork and connected it to my DC. I mounted old tooth brushed in mine to clean the wheels.
You can order both parts from Iturra Designs. They don't have a website but they have a wonderful catalog that is nearly an instruction manual for these saws. Perhaps someone will chime in with his phone number. If I were you I would call him and order the brushes (a few bucks) and he will send you the catalog. A very worthwhile source of information. Ask him about dust collection while you have him on the phone.
I could post pictures of my set up if you want to see them.
Iturra Design number
D. Hansen
When I ordered some cool blocks from Iturra Design their number was 888-722-7078 but that was way back in 2002. They were a big help with several bandsaw related questions.
Dick Hines
Re: Iturra Design number
Dick Hines
Roger, take a piece of duct tape as long as the left slot. Then tear another piece as long but only half as wide. Put the narrow piece in the middle of the wide piece. Then wrap the tape over the slot. Works on my Jet.
Don't just use tape because the saw dust will build up on the sticky tape.
Years ago I bought a cheap brush at Walmart, cut it in half, and fastened the halves inside the saw. But I also recommend asking for Iturra's catalog which full of useful information as well as products.
Roger I sealed the doors and other gaps as best I could. I cut away part of the cover just below the bottom bearings and built a custom holder for my dust hose, and installed some brushes. I still get what I think is way too much dust or shavings coming from the machine.
I think cutting a hole in the bottom of the door would be just as effective and a lot easier than what I did. I don't know where the dust comes from but after I cut a blank there is a huge amount of dust on the table and consequently all over the outside of the machine. The inside is reasonably clean which at least suggests that the brushes and dust collector are doing something.
I also have a lot of sawdust directly under the table on the supports for the table. I don't know how to collect that short of adding another smaller dust hose with a port right at the bottom of the insert for the table.
We are assuming you have dust collection and want to add it to your bandsaw. While dust collection is an excellent Idea, that my not be what you are doing. My saw came with a port on it for dust collection. It was a little plastic thing with a tube for a shop vac mounted below the table and at the lower bearings. I hated the shop vac because mine is noisy and it was in the way.
Like John, my first shot at it with the DC was to cut a hole through the lower door and and install a four inch port. It worked well enough, but was hateful when you tried to change the blade. It was like the door was spring loaded and had to be propped open. Then I found out Delta had the port I mentioned and was angered that they had not made that obvious in the literature they sent me with the saw. I was so ticked that I had cut into my new saw I called them and complained. They sent me a new door. (Actually they sent me two because they sent an upper door first, labeled as a lower, then they sent me the correct one. I told this tale here on Wood Central and somebody wanted the two spare doors and I gave them to them.)
For more than you ever wanted to know about dust collection, go billpentz.com. I highly recommend Dust Collection even if you just hook up the shop vac. Rummage around in Bill's site. There is a section on how to hook up most machines. See what he says on bandsaws.
iturri info is veery helpful
bob davis
Re: Iturra Design number ***Correction**
Bartimmo
Iturra's number has changed. The 1-800 number in the previous post no longer works. Just called it and spoke to gentleman who was kind enough to pass on their Iturra's new number....the new number is (904) 642-2802.
Roger in MO
Re: Yes and Yes
Roger in MO
I would very much appreciate pictures. rhink at ctcis.net
Thanks. Roger
Roger in MO
Roger in MO
Thanks for the responses. I talked to Iturra just now. Delta no longer makes the dust port and he had no suggestions for making my own. He is sending a simplified product catalogue without all the articles so I can perhaps place an order and receive the full catalogue. Also checked out the billpenz site. Several ideas there.
Back to the drawing board to see what I can devise.
Roger
Pictures
The boot is connected to the unit with an Eye bolt that loops around the bolt that used to hold the little factory dust port.I remove the port to change the blade. Loosed the bolt and lay the port on the floor. The blast gate on the DC hose is one of th Long Ranger ones that turns on the DC when I open the gate. With some more thought it may have been possible to fix the boot so that it could stay in place while the blade was changed.
You might consider a store bought solution. My tooth brush appears nearly toothless.
When I opened the saw for the picture I realized debris from the lathe was about half of what was in the saw. Maybe I should run the DC on the BS while turning on the lathe. (Play the Small Shop Blues here)
Roger in MO
re: Pictures Thanks
Roger in MO
