Re: Cracked Bowl blank Questions
Greg Haugen
barry,
I'm just going to run through things to trouble shoot cracks in general.
First thing to be sure of is to never start with cracked wood. It sounds silly but I've seen people do it a lot. Don't start to turn it until enough has been removed to ensure all previous cracks are removed. Cutting 1 inch off of the end of a log doesn't take care of it all of the time. If they're cored blanks or if the blanks would have been stacked in the tree, and the cracks are close enough it could have been a crack there already.
Even wall thickness is essential. If you'll error to one side, a thinner bottom is safer than thinner sides. The sides will move more and will dry faster than the bottom due to the amount of end grain.
If I have a bowl that's over 1/2" thick, I'd anchorseal it (mainly on the end grain inside and out along with the rim) and either "store it and forget about it" or put it in my kiln. The paper bag or cardboard box methods usually works better with thinner bowls. 1" thick wet oak is a lot of wood to dry without slowing down the end grain.
Wet wood that's drying should be kept cool with little to no air movement to start. A higher relative humidity isn't a bad thing to start since it will lessen the "shock" on the wood as it dries. I'll often time leave them in the shop with the humidity from the shavings for a few days. Basement floors are a good option, if available.
If something is finished turn green-get it thin, get it an even thickness, and let it sit to dry.
What to do with these now? You could finish turn it and...
accent the cracks with inlace and epoxy.....
if you can cut a butterfly, you could patch it with a butterfly or you could add some straight stitching like some of Ellsworth's or Jerry Kermode's work.....
carve the rim to accent the cracks like the bowls on the cover of Raffan's "Art of Turned Bowls" book.......
Or you could just let it dry and see what you have left. Some say cracks in Oak will get smaller or possibly close when it's fully dried-then finish turn it and mend it or accent it in some way.
I do cut wood most of the year, except for the insanely cold months here in Wisconsin of Dec. and Jan. and even then I'll suck it up for the right wood. I haven't had much of a difference between seasons except for the bark coming off easier on the natural edge bowls from the logs cut in the spring and summer. I'm also pickier about what I cut now than when I first started. As John Jordan would say, "Life too short to turn _____ wood."
Hope that helps.
on the bright side, it does grow on trees and you had fun.
