14" bandsaw questions
Roger in MO
Roger in MO
I'm looking at a Delta 28-262 bandsaw with riser block.
I'd appreciate any comments, good or not so good, about this model.
Thanks. Roger
Re: 14" bandsaw questions
Bill Youngblood
I have a Delta with the riser block. I put Carter roller guides on it and it was a huge improvement. I now resaw 1/16" veneers cosistantly. It takes a while to set up, but is well worth the time. Also, use good quality blades. Good luck.
Ken Oakley-Sunny St. Cloud, Fla
Never found a Delta machine I didn't love. I have a 14" bandsaw with the riser blocker and Carter roller guides also. Does everything I want it to do. I bought this one new in 1996 but have worked with Delta machines since 1961.
Re: 14" bandsaw questions *LINK*
Russ Fairfield
Everything I know about the Delta bandsaws is on the linked pages of my website. It may be helpful for purchasing, using, and maintenance.
The new saws of the last 2 or 3 years by all manufacturers are an improvement in quality and performance over some of the older models.
http://www.woodturner-russ.com/Bandsaw-Using.html
Roger in MO
Thanks Russ, I bookmarked it Roger
Roger in MO
