How to Reduce Photo File Size?
Al Kapocius
As a Luddite, I've never had to post a picture before. I've seen threads previously covering the subject but I don't speak enough computer to find them. I'd like to know how to reduce photo file size from some 200 kb to the 80 kb or so required for posting.
For what it's worth, I've got photos stored on HP Photosmart Essential.
Al Kapocius
Re: How to Reduce Photo File Size?
Dinyar Chavda
Al:
Tools for resizing are available in most photo-editing programs like Photoshop, Elements, Paintshop, etc.
What I find most convenient is a free Microsoft Powertoy (I assume you;re using Windows, Mac probably has this function built in), which you can download at http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe .
You'll have to cut and paste the above link. Once you download and run it, it will add "Resize Pictures" to your context menu.. So, if you have a photo, click on it with your right mouse button, and you will see "Resize Pictures" as an option. Click on that and it will give you multiple size choices. Play with them and you'll get a feel for what option will give you the right size.
Hope that helps.
Chuck Jones - West TN
Al,
I just tried to install the Microsoft add-on that Dinyar mentioned because it sounds like a pretty neat and convenient tool only to find out it is not compatible with Windows 7. The message said it was for Windows XP. I don't know what Windows version you might be running, but you may have problems using it.
To my surprise I discovered that HP Photosmart is installed on one of my computers. I took a quick look at it but decided I did not want to spend enough time wading through all the marketing noise. However, I did see that it has an edit feature including "resize". That might have the capability to get your photo down to the file size you need. Poke around through it and see.
In essence the generic steps that work toward reducing the file size are:
CROP - lop off everything that is not essential to the photo
RESIZE - change the dimensions of the photo to something smaller than what your camera recorded.
REDUCE THE QUALITY - usually done by a SAVE AS action with a lower quality selected.
The specific terminology and steps are going to vary with whichever of the zillion photo editing programs you are using. Most of the ones I have are older and it wouldn't be helpful to go into detail about them.
You might also want to look into changing the size setting in your camera... a subject I know even less about.
(By the way photo size and file size are related but not the same thing. Other factors also effect file size.)
If this doesn't help I'm sure someone more knowledgeable on the subject will pitch in later in the day. I'm not a LUDDITE but I'm certainly OUTTA DATE.
Re: For Win 7
Dinyar Chavda
Chuck:
I haven't used it, but here's a clone that's supposed to be compatible with Win 7:
http://www.addictivetips.com/windows-tips/image-resizer-powertoy-clone-for-windows-7vista/
The other possibility is to open the picture with Microsoft Picture Manager, and one of the options under Tools is Resize. You can put in a %, but my guess is that it would take some attempts to get it to the right size.
Re: For Win 7
Carol Reed
Actually MS Picture Manager is even easier. There is a 'resize for the web' button.
Thanks Carol...MS Picture Mgr.
I've had Microsoft Picture Manager right under my nose for years and never looked at it. It's about the easiest to use and most practical pic mgr out of the 5 or 6 that I have on my computer.
Thanks for the tip!
Re: Thanks Carol...MS Picture Mgr.
Carol Reed
You are welcome.
I love simple, too.
