sweet gum
sweet gum
Bob
sweet gum
Bob
I just received some green sweet gum wood, i have never turned it, does anyone have some experience with turning it,
Re: sweet gum
Re: sweet gum
Barbara Gill
I never have turned any but I have sawn quite a bit. It warped terribly. If I ever saw any more it will be quartersawn.
Re: sweet gum
Re: sweet gum
Tom Collins
I turned some earlier this year, it turned nicely but cracked terribly while drying and ended up in the wood stove. I have seen some beautiful pieces made from sweetgum with some spectacular spalting. Evidently it needs extra care when drying
TomC
Re: sweet gum
Bob
Re: sweet gum
Bob
I turned 4 bowls today and put wax on them, hope they don't crack. Thanks
Re: sweet gum
Dick Hines
Re: sweet gum
Dick Hines
I love turning gum. people can't beleave the beautyful bowl is turned form gum
It it is wet make sure you wear a rain coat.
I soak all wet wood gum included in denatured alcohol and it dries fine.
Re: sweet gum
Re: sweet gum
Emmett Manley, Lakeland, TN
Sweet gum is one of my favorite woods -- turns like a dream and the aroma is delightful. The wood is always pretty, and sometimes spectacular. It does want to warp so I suggest just turning your bowls to the final thickness and hope for the best. You can improve your chances of minimal warp and no cracking by doing the usual things -- wrap in paper or towels, keep out of moving air, perhaps a little wax or sanding sealer to slow moisture loss, etc.
In my opinion, this wood is worth the trouble. I just made eight bowls from a sweet gum log that was blown down last June 12. So far, so good, and I can live with a little warping which provides character.
Re: sweet gum
Re: sweet gum
GaryG in MD
Bob, Try turning a bowl green and thin to final form and thickness. Double brown bag it for a week and oil it. Just let it warp and hope it doesn't crack. It could be very nice.
Sounds like a good wood to make sculptural tubes out of. They'll bend in all kinds of crazy directions. There are lots of examples on WoW, but I can't find any in the WC archives. See for example Dick Veitch's at
http://www.sawg.org.nz/Galleries/members%20galleries/dick%20veitch/2008/index.html
...Gary
Re: sweet gum
Re: sweet gum
Bill Turpin in WNC mountains
Did you collect any of the SG sputnik seed balls? Fill a piece of 3/4" PVC with them. Pour in some clear polyesther resin and cure. Turn the plastic pipe off and you have an interesting pen blank.
Re: sweet gum
Chuck Jones - West TN
I like sweet gum, but...
like all species I've found a lot of difference from one log to the next. The heart wood in large, old sweet gum (called red gum) is quite nice either for lumber or turning. I've found some of the smaller trees to be not so exciting. Here is a sweet gum box, one of the first pieces I turned from any wood... well at least one of the first I kept. Not a very good photo, but the wood is beautiful in person.
Re: sweet gum
Re: sweet gum
The sweet gum I have has wonderful soft pastel colors. What I turned was wonderful, soft but clean. It did warp significantly. I cut a bunch of blocks and turning squares that I'll let dry for a few years.
Re: sweet gum
Re: Emmett- am I correct that sweet gum...
JamieDonaldson
... is also called tupelo in your area? I have turned some of both years ago, and found great variation in the color from tree to tree, but all I had was chunks. Much of the sweet gum color from this part of KY is unspectacular at best!
Re: sweet gum
Re: sweet gum
John Jordan
If it's a large tree, the colored heartwood is sold as "figured red gum" or, "satin walnut" The white sapwood is sold as "sap gum". :) As pointed out, it moves a lot, but it turns really nice, and can be really pretty if there's some color.
Tupelo refers to black gum, I believe.
John
Re: sweet gum
Dennis in Southern Oregon
Re: sweet gum
Bob, I turned a couple of hats from sweet gum this month and found it a joy to turn except for the torrent of sap that it produces. The shrinkage was less than that of madrone, which I have used in the past, and the color of the sapwood after drying was nearly white. Dennis
Re: sweet gum
Emmett has more knowledge and experience with wood than I do so I am anxious to see his answer. But you might be confusing sweetgum and blackgum. Blackgum is often referred to around here as "Tupelo". In most references there is a tree called "Swamp Tupelo" and "Water Tupelo" that are listed as different species but in the same family as blackgum. Sweetgum is in an entirely different family.
Discussing tree names with my rural West Tennessee friends is akin to discussing politics. Somebody is gonna get mad... and I've found you can make 'em even madder by citing reference books. 8)
I have several blackgum trees on my property. They are pretty trees and great food for the birds, but I've never sawed or turned any.
Re: sweet gum
Sweet gum is easily recognized by the five pointed, star shaped leaves, and the distinctive fruit pods (gum balls). Easy to work, non-irritating (in fact, great aroma), easy to finish, etc. If it did not like to warp so much it would be a nearly ideal wood.
The Tupelo gum is closely related to the black gum, which is a totally different tree. The Tupelo variant will survive, even grow, in standing water and our swamps around here include a lot of Tupelo gum. Black gum is much less common these days and it, too, can be a very pretty wood for turning. In the forest, and especially along old fence rows, the black gum stands out with its central trunk predominating (often a den tree for raccoons, etc.) -- making up much of the tree. The black gum has shiny tapered leaves which turn a glorious crimson in the autumn.
So, that is a long answer to your question. Tupelo is not the sweet gum -- not even close, but black gum is closely related although they don't look that similar.
Re: sweet gum
Bob
Re: sweet gum
Bob
Thanks a lot for all the info. on sweet gum. Bob
Re: sweet gum
tree names
That's why having the species name is so helpful. Even the common names the "experts" give are often biased by their own region and what their grandpa told them. I'm certainly no expert so my reference books stay close.
They can argue "gum/sweet/red/black" all day but it's hard to disagree with nyssa sylvatica or nyssa aquatica or liquidambar styraciflua as long as there is a positive ID from leaf, flower, fruit, or microscope. Besides, the big names tend to quiet some who know more than they know.
Re: sweet gum
Barbara Gill
Also Sweet Gum is often sold with the heartwood being cut into boardsand the sapwood into seperate boards. The sapwood is sold as sap gum.
I wish we had more Tupelo on our farm. As far as we know thereis only 1.
Re: sweet gum
Re: sweet gum
Barbara Gill
During WWII most of the Black Walnut was going into gun stocks. Many church pews that look like walnut are heart Sweet Gum.
Re: sweet gum
Re: tree names
John, you are exactly correct -- using the (Latin) Genus species names usually provide positive identification or at least gets everyone on the same page. In the case of the black gum, Nyssa sylvatica, this is complicated by the all of the common names used by even the "experts" and the fact that the Tupelo gum which grows in water is often lumped in with the black gum/black tupelo which is a dry land tree. I have been around both of these trees over the years and they really don't appear that similar to me.
Probably we have beat this dead horse enough. The original discussion was focused on sweet gum, which IS an easy tree to identify.
