Center Finder Question
Re: Center Finder Question
Teknatool has a reasonable one *LINK*
They call it a Chuck Gauge. They are sometime given as freebies at Woodworking shows.
Teknatool 10 in 1 gauge
Mark Wollschlager
I have the Veritas Center marker and like it.
It is sturdy and simple.
They have them direct or Woodcraft ( among others ) also sells them.
I also have a yellow plastic center marker, which is ok because you can lay it on the work and sight the center in a different way ( also from Woodcraft or Craft Supply among others).
Mark.
Steve Kubien
Steve Kubien
Scott, I just use one of the cheap, yellow, plastic jobs. For things like table legs, peppermills, etc it is not real critical to have exact centre. When drilling small stock like for pens it gets much more important as you don't want to blow through the sides.
Just my 2 cents.
Bill Howatt
I have the Vertias one from LV as shown by Mark. It works but I can't say it is my first choice all that often for some reason. Might use it more if I kept a hammer near it.
For "square" stock I may just draw diagonals with a straight-edge and mark the center with a small drill hole.
I admit that for "round" things, I often use "set and try" with a compass.
It could be that my preferred method may be what I'm standing near in the shop.
Bill
Re: Center Finder Question *LINK*
Fred Holder
I have had the Veritas Center Marker since it first became available and use it regularly to mark the centers on square or round stock that will fit in it. I also have the Gauge Master by Vicmarc. It is aluminum and very stable. I use both on a regular basis.
More Woodturning magazine
Re: I use a "trained eyeball" technique .....
JamieDonaldson
...and don't have to waste time looking for a tool!
Russ Fairfield
I agree with Jamie. It is easy to split a square in two directions by eye, and that's close enough for most things. I use a rule when I want precision or don't trust myself.
I use a pencil and trained eyeball. Grab a pencil with your fingers and thumb so some of it sticks out kind of like a marking gauge. Make a mark across the square piece dragging your fingers against the side. Do this on all 4 sides and you have a smaller square marked off in the middle. It's very easy to find the center of this smaller square.
Round stock. I just eyeball the middle in one direction, then rotate it 90 degrees and split the middle again. I'm usually really really close.
Soren Berger method
John Kaner
John,
That's how Soren does it. He was up here a couple years ago for our symposium. He said it takes into account the sides might not be perfect square.
When the lampshade self destructed, and it was thin, real thin...
He said "it's just wood"...
Tery Scott
A perspex disc with diminishing circles and a center hole I have these in many sizes they work a treat
Mike Stafford
Mike Stafford
It is easy to make a center finder. Just cut a piece of plywood into the shape of a framing square with both legs the same length. Bisect the 90 degree angle using a a 45 degree square and screw another piece of plywood onto the right angled piece along the line formed by the 45 degree triangle.
If you are concerned about absolute accuracy of your centers use the center finder from all 4 corners and then mark your center where the 4 lines intersect or don't as the case may be. Whether or not you end up in the exact center will still depend on whether the awl you mark the center follows the grain or not. Same for the point of the live center point.
Jamie's eyeballs are calibrated to ASME standards. He also has calibrated fingers as I have seen him measure with his fingers accurate to 3 decimal points....really! :b
NOW you tell ME?
I saw Jimmy Clewes do this at a recent demo. I tried to buy the pencil, but he gave it to me. Now you tell me the magic was not in the pencil?
Tery Scott
Have to admit to using my builders gauge mostly
With Finger and pencil scribe a line from all 4 sides
The "pencil marking gauge" is the method I've always used and taught. It is very accurate and done before the other guy even finds his gauge. It works well even if the blank is not even close to square and if the sides are not perpendicular.
After I make the four lines I use a little gimlet to make a shallow hole at the center of each end. This lets me position the centers precisely and quickly and as a bonus minimizes splitting in thin blanks of brittle woods.
Damn...
Scott Burr in Ben Lomond CA
Thank You all!
I'll be skipping the CF (center finder) I've used a framing square for years. A speed square makes for fast work as well.
Thanks your all great!
Re: Those are my digital calipers Mike!
JamieDonaldson
Don Geiger
Don Geiger
Check out Geiger's Re-Centering Solution at:
www.geigerssolutions.com
