Old bandsaw blades
Old bandsaw blades
Old bandsaw blades
John Leonard
Hi Gang, I have 7 or 8 years of old used up bandsaw blades hanging in the shop. :b How is the best way to get rid of them? Thanks in advance. John L.
Re: Old bandsaw blades
Carefully
If you have a scrap metal yard they will probably take them and may give you some money to boot.
Steven Antonucci
borax and a coal forge
Steven Antonucci
and a try at bladesmithing?
Pattern welding old blades might be fun...
Steve
Dick Coers
I fold mine up as tight as I can get them, then hit the fold with a hammer. I then have straight pieces about 18" long and it's very easy to recycle. A bit like working with steel banding.
Don Evans
What I've done is roll them back up like they were when they came, then take a large enough piece of thich cardboard box and cut it so it will fold over the blade, then tape it up with duct tape. It can then be put out with the trash.
You may want to consider cutting, with tin snips some of the wider ones like 1/2" and larger. These can be used with a scraping block to make cutters out of grinding the end of the cut blade. You will want piece about 1" to 2" long depending on your home made block. You can then use them to make crapped grooves for inlay (holly, in dark wood) etc.
Make he cutter with grinding and filing, not just grinder as stated above.
If you belong to the internet version of Fine Woodworking they have videos on this procedure. Both making the block, cutters and using them, even how to make the inlay.
Don
coiling and uncoiling
>...What I've done is roll them back up like they were when they came...
One caution, if the blades are heavy be sure to wear safety glasses in case the blade gets away from you! The only time I was ever hurt by a bandsaw was a scratch when uncoiling a blade.
The big Woodmizer blades for my sawmill are especially fun to coil and uncoil. It took a bit to learn the coiling but I finally got the hang of it. To uncoil I remove the ties and throw the coil on the ground well away from me.
Re: borax and a coal forge
R Payne
If you aren't up to trying a hand at blacksmithing you can probably find a blacksmith in your area who would love to have them. May even be willing to trade some work for them.
ron
Texian
Probably irrelevant to this thread, but 6" lengths of used metal-cutting bandsaw blades (~1" wide) make dandy thin parting tools.
Thats funny...
Thats exactly what I do. I don't have too much trouble coiling them, but uncoiling them is a differrent story. They seem like they might strike like a cobra. I take them outside and fling them out into the grass.
Emmett Manley, Lakeland, TN
I've seen woodturners use old bandsaw blades as drying supports for small items where you want minimal contact of the finished wood with the support.
Re: Thats funny...
I need to make a video of the guy who sharpens my saw blades. He coils and uncoils bandsaw blades that are 5" wide. I watched him coil one into 1/3rds and then coil it again into 1/3rds. If that thing got away from you it would cut your arm off. Next time I go I'll take my camera and see if I can get a movie of him doing that.
Chuck Jones - West TN
That's good to know. I have enough old Wood-Mizer bands for... oh, about 698 parting tools. Anybody need an extra one?
I break mine into smaller pieces and put them in a friend's scrap bin at his Tool and Die shop. It's always good to be friends with a tool and die shop.
charlie belden
I've got a small koi pond that racoons and egrets think is a sushi bar. I finally took some old bandsaw blades, pulled into a "Y" and zip tied. Layed over the pond, teeth up, the make great "discouragers". Found fur on one - once. Haven't lost a fish since.
As for making parting tools, old bayonet saw blades work better.
Related?
Tony - Memphis
Memphis isn't really my last name! I'm a Leonard too. My dad and his bunch are from the Pensacola, FL and Foley, AL area.
Tony
Re: Related?
John Leonard
Probably not, I am from the Panhandle of Texas and my dads's family came there from arkansaw back in the early 1930s. John L.
Re: Thats funny...
There are some videos on the 'net on how to coil. For the big blades I put my foot on one part against the ground (teeth away from me), hold one side of the loop in each hand, then push the sides together such that the top bends down and away (if I'm remembering correctly, don't have one in front of me right now!), forming one loop of the coil. The rest of the blade sort of "falls" into place. I tried this numerous times with spotty success until one day I "got it" and from then on it was simple.
