continuing the skew saga...
GaryG in MD
Per below, I am now a proud owner of a DT 3/4" skew.
I need to put a handle on it. The active length of the blade is 6.25".
What do you reco for a handle length?
Too short is obviously not good (except for some odd cases I don't intend to get into right away), but too long can also be awkward, altho I would certainly want to err on that side.
So, what handle length do you like for such a mid-sized skew, and why?
Does your answer change if it is wood or if it is (heavier) metal?
Thanks, Gary
Re: continuing the skew saga...
Jorge Casta�eda
Gary,
I like 12"-14" wood handle for a skew, except my 1/2" has a 9" and of late I've been using my 1" without the handle. I use a metal handle only for travelling.
Harry in Beautiful Downtown Kulpsville
Gary, I just measured four of my skews ranging from a 1/4" round one from Bob Rosand to an 1-1/4" one from Doug Thompson. All measured just slightly over 10". All feel comfortable to me. I did make the handle of the DT a little fatter than the rest and that feels even better.
Russ Fairfield
Like everything else about the tool, the handles are a personal preference. I like a short handle that is about 7" long on a shorter tool, so I can maneuver the tool in front of me, and not to the side where my body gets in the way of moving the long handle. It is also easier to see where and how it is cutting. Try it. You might like it.
The two skews I use the most are my older oval 1" skew and Thompson 1 1/4" skew. Both have handles pretty close to 14". My 1/4 and 3/8" skews have handles that are closer to 6". These are used mostly for ornament finials so I wanted to keep the size down.
Chuck Engstrom
Hi Gary -- I potted the tang end of my 3/4 DT skew into a length of 0.500 OD brass tubing with epoxy plus hard filler powder. This enables me to use it in a home-made multi-tool handle which grips the tool with a 1/2 brass tubing clamp as for copper gas lines. The handle itself is about 14-1/2 inches overall, with some lead shot in the butt end, and I use if for bowl gouges, hollowing tools, etc. and find it about right for them. I used it today with the skew doing three ten-foot porch posts, but I also used a shorter skew in a shorter handle for a couple of spots on them.
Best--
Chuck
These are great answers...  please keep 'em coming
GaryG in MD
I'm enjoying the variety of responses -- lots of factors to think about.
I'd love to hear even more considerations...
Mike Peace
Mike Peace
I bought a nice 3/4" Jet skew made in Sheffield, England and it has a very short handle, 8 1/2". I find that it is my favorite and the length is just right.
CSUSA in their catalog recomends a handle to be 5 times the max distance you intend to reach over the tool rest. I rarely use a skew on anything more than 3" thick so the distance is 1.5" (radius) + 1/4" gap between wood and tool rest times 5 comes to 8.75".
My Harbor Freight tools have 10" handles including the skews. That length seems ok but I find myself chokeing up a little on the handles of the skews.
I've been using shorter handles lately for spindle work where there are never large forces as when manhandling a large bowl or hollow form. Expert turner and instructor Frank Penta recommends shorter handles, as proven in the trades. More maneuverable.
I also use spindle gouges, small scrapers, and small skews without any handle for small work.
My skew collection. A like the skew and use it a lot. Consequently I've played with all kinds of grinds and shapes. I continue to modify one when I want to try out some new grind. The biggest skew is 2" and smallest is .025" . As you can see the handles go from 14" down to quite small.
Probably my favorite is the one I made from a 3/8" spade bit. It has a 1/4" round shank so it rotates on the tool rest very easily and the 3/8" blade makes it easier to control where I am on the cut. I use it more than my 1/4" round skews.
for small projects I like a short handle. For larger projects I use the handle against my body just like I do the bowl gouge so I like the longer handles.
and the answer is...
GaryG in MD
OK, I get it -- the answer to long or short handles is "YES" -- MORE TOOLS!
Cool, I can dig it.
The important thing is obviously the application.
For that, I'll just have to start experimenting.
Thanks to all for your excellent answers.
John -- that's quite a collection -- thanks for the image. ...Gary
One more thing,
Jorge Casta�eda
Like John I use the skew a lot and have several; now I am making my own handles and like to be able to sharpen without the handle, so I use ferrules and thread them to receive a set screw.
Makes life easier and a lot safer at the grinding wheel.
Something to think about.
Re: One more thing,
GaryG in MD
Excellent point -- I wouldn't have thought of that -- thanks a lot -- that changes the way I was going to go about things -- I'm thinking now of using a Dave Peebles handle, or maybe a Trent Bosch -- Doug says the tang of the skew can be rounded to fit a 1/2" round hole. Sounds like a plan. If you're reading, Dave, you may get an order soon. ;-) ...Gary
GaryG in MD
Thanks Mike, That's very good info. I think my initial reaction was to use a handle that may be a little too big for it. This gives me food for thought, along with the other excellent replies. ...GG
