OT: Inserting shells and rocks into backsplash
ILYA Z
We were recently traveling overseas and visited a desert and some beaches. As the result, we now have a small collection of interesting looking shells and rocks. Now that we are remodeling our kitchen, we had an idea of somehow incorporating them into the backsplash. The attached photo shows mostly the rocks. I have no idea what type they are (sedimentary/volcanic/etc). The main question is: given their odd shape and varying size (e.g. the one at the bottom of the photo is about 3" X 2.5"), is there any way to attach them securely to the wall? Do we need to use some special type of adhesive? Do we need to prepare the rocks and shells in any way, e.g. clean them in a special way, polish them etc? Once installed, is there any way to make cleaning them, and the backsplash areas around them, easier?
Thanks much!
Re: OT: Inserting shells and rocks into backsplash
Don Central Illinois
They should be clean of any dirt or grease, etc. and you should be able to attach them with thinset, mixed a little thicker than for tile. As for cleaning them afterward, possibly a toothbrush. Good luck and make sure you post photos afterward.
ILYA Z
Thanks, Don. Thinset is white, correct? Is it possible to mix it with anything to color it? I am asking because unlike with tile, a lot of thinset will be visible because the rocks have irregular shapes and sizes and can't be placed too close to each other. So I am not sure whether the white will look good, maybe a different color.
Bill Howatt
I suggest you mock this up with various background colors etc and see if it really works before you expend a lot of effort on your backsplash and find you don't like the result.
Bill
Stuart Johnson
I don't think I would try to attach them to the backsplash by using thinset or some other adhesive. I'm afraid you might end up with something looking like a miniature rock climbing wall. It will be hard to keep clean and will likely end up with a build up of grease and dust in some of the crevices.
One thing you could do is take them to lapidary shop and have them sliced into 1/4 inch or thicker slices and then polished and sealed. From there you could mount them just like tile either on the backsplash or possibly a wall hanging. The shells can also be cut in half and maybe set in epoxy.
bill crommett
If you are going to color your thinset, remember that wet thinset will have a darker color when it is still wet than when it dries. Yesterday I mixed up some tile gray tile grout with blue dye to match some repair grout that had crumbled. Blue grout has gone out of style in 20 years so I had no choice. Anyway, our kitchen floor has patches of powder blue grout and patches of pale blue grout.
Thinset is usually a grayish color, but that is the adhesive part. After is is on the wall, then you grout in between the tiles/rocks/shells and it comes in many colors. I like the idea that, I think it was Bill, had, slicing into thin pieces. Then it would be more like tile. Otherwise, it will be hard to clean and will look like a minature rock climbing wall.
Chuck Jones - West TN
My wife changes her mind about what she wants on the kitchen counters and back splash about--oh, every couple years seems like. That might make the wall hanging idea mentioned earlier worth considering.
