A55 Smoothing Plane
Fear the chuck
Fear the chuck
Dick Hines
Fear the chuck
Dick Hines
I was turning a small foot for a small box ths afternoon and got to close to the jaws of a spinning chuck. Well, my finger did. It takes a long time to sand blood out of a piece too.
A word to the wise keep your fingers and other body parts away from a chuck spinning at high speed.
Re: Fear the chuck
Re: Fear the chuck
bill crommett
Is there a way to learn this behavioral trait that is NOT bloody ?
Re: Fear the chuck
Re: Fear the chuck
Wally Dickerman in Arizona
Way back before 4-jaw scroll chucks, we sometimes used 3-jaw machinist's chucks....Now THERE was a real knuckle-buster.
Wally
Re: Fear the chuck
Re:I cringe when I see some very........
JamieDonaldson
...experienced turners put their hands on a chuck to slow down the rotation to a quicker stop! :O Think what would happen if a finger fell into a chuck keyhole as it was spinning! :O :O
Re: Fear the chuck
Jeff Willaford
I almost did that ONE time but thought better. I also don't slow via the blank. That's why I have a handwheel. See, Mom, I CAN learn from others.
Re: Fear the chuck
Over the weekend I was at a friend's house. Washed my hands and turned off the water. The tip of my ring finger slipped into a slot in the single lever handle. I over reacted and snatched it out. It's still tender.
You are right about those holes in the chucks. I have the older SuperNovas that use that hateful key. It has occurred to me more than once you could loose a finger in one of those holes.
Go to a tire place and get a small inner tube and cut it into rings. Put the ring over the chuck. You can also put a small flap of tape on the chuck to warn you your hand is too close.
Re: Fear the chuck
Would it?
>...It has occurred to me more than once you could loose a finger in one of those holes.
It does seem frightening, but at speed, I wonder if you could even push a finger fast enough to get your finger far enough into the hole to catch and cause serious trauma such as dislocation or fracture.
Consider a 4" diameter chuck running at 1000 rpm. If my scribbles are close, the surface would move at over 200 inches per second so a one-inch diameter hole on the circumference would move past a given point in less than 5 milliseconds. Subtracting for a fat finger, the window for a "clean" insertion would be quite short, perhaps around 2 milliseconds. Seems it would take a pretty high muscle acceleration to get the velocity high enough to insert a finger a significant distance (1/2" to 1"?) in 2 milliseconds. Haven't measured, but judging from my piano playing I don't think muscles work that fast. (Someone check the math.)
If this is the case, it seems like one would have to be so fast with a finger stab that perhaps a skin abrasion might be the worst of it, unless of course the rim of the hole was sharp like a knife. (Ever hold your hand against a spinning fan blade? It's moving so fast you cannot easily (or perhaps actually) stick your fingers between the blades - they just bounce of the blade. The things curious kids do...)
A simple experiment of trying to push something into the hole while the chuck is spinning might give some indication of the actual potential hazard level. If I have time I'll try this tomorrow.
As for slowing the lathe with the hand, this is impossible on my lathe (Jet 1642) since the vs motor controller actively decelerates the spindle (under power) instead of simply coasting to a stop. After you try slowing it once or twice with the hand "wheel", you never bother trying it again.
Re: Fear the chuck
Bill Grumbine (Kutztown PA)
Some of us just watch it spin down, instead of sticking our hands in where they don't belong. I can still count all the way to 10, and I intend to keep it that way. ;)
Re: Fear the chuck
Re: Would it?
John, all you need to do is catch the trailing edge of the key hole to get your finger wound up good.
As for slowing the lathe down by grabbing the hand wheel, lathes with larger motors, even with dynamic braking, can heat your skin up pretty good. DAMHIKT
Re: Fear the chuck
Re: Would it?
John Jordan
Many people turn the tenon too large, leaving the jaws extended outside the body of the chuck. :O Not the best way.
John
Re: Fear the chuck
Carole Valentine
I'm guilty of slowing by putting my hand on the blank sometimes (after it is smooth) but I know I shouldn't...one of these days I am going to get the mother of all splinters! Would NEVER try and slow the piece by grabbing the chuck itself though.
Re: Fear the chuck
Don Pencil
Re: Fear the chuck
Don Pencil
Any sissy can slow and/or stop a chuck with a little loss of skin from the knuckles or fingers!
Real men (and/or women) just use their kanine teeth to do the job.
Be Well,
Don Pencil
Re: Fear the chuck
Mike Stafford
It happened one time...
Mike Stafford
One time my hand came into contact with the spinning chuck and the resulting laceration and bruise were enough for me. I bought some of those bright multi-colored scrungies which I place over the chuck to protect my hands from those sharp metallic corners. And I don't let my hands get near the chuck anymore. The man of steel I ain't!
And John Jordan is right; over extending the jaws is just asking for trouble in the worse sort of meat grinding way.
Re: Fear the chuck
Bill, I didn't know that you ...
Ed Moore in SW VA
turned barefoot! Don't drop your skew! :D :D
Ed
PS: Those Rib Country ribs in Murphy, NC, are good aren't they?
Re: Fear the chuck
Re: It happened one time...
Carole Valentine
Good thing about the SN2s - you can't over-extend them even if you want to.
I have done the barefoot/sandals dance once or twice...it's still a risk I take though, as I absolutely hate closed shoes in the summer!
Re: Fear the chuck
Dick Hines
Dick Hines
The chuck jaws were not over extended. I was turning a piece of blackwood for a box foot. It was less than 2" in d. I was in the sanding mode and just got my index finger of my right hand to close.
"When you are stupid you are supposed to suffer."
I did finish the box, after I got the bleeding under control. A piece of paper towel and some masking tape work every time.
Re: Fear the chuck
Don Pencil
CA for blood loss control
Don Pencil
Re: Fear the chuck
Dick Hines
Re: CA for blood loss control
Dick Hines
I had rather bleed. My wife used some New Skin on me one time. I thought she had set my hand on fire. New Skin is about the same thing as CA.
Re: Fear the chuck
Re: Chuck covers
Steve Harder
Where did you get your chuck covers?
Re: Fear the chuck
Rob Wallace
Re: Chuck covers *LINK*
Rob Wallace
Steve:
You can get them at Lee Valley Tools
I use mine only occasionally when the jaws are a bit too extended...
Rob
Lee Valley Chuck Cuff
Re: Fear the chuck
Don Pencil
Don Pencil
Not recommended for use with excelerators.
Great for when you start a break in a finger nail and the break will continue back into the nail bed. CA then a nail file does the trick.
Re: Fear the chuck
Steven Antonucci
Depends on the lathe and situation
Steven Antonucci
I use my hand to slow down the lathe, but not all of the time.
Undoubtedly, the safest thing to do is wait. There are many variables that will influence my decision to use the chuck as a handwheel. Some that instantly disqualify that idea:
lathe running above 1000rpm (Bill's point about hot fingers)
What lathe am I turning on? (A Oneway DOES NOT SLOW DOWN until it wants to)
Are the jaws extended? (they shouldn't be, but we all do it)
What am I doing? (Am I really in that big of a hurry?)
What's in the chuck? (More momentum in a large bowl blank than a pen blank)
Is the toolrest anwhere near the chuck? (Really don't want to get trapped between them)
I suspect that using the chuck properly is your best course of action, but when I do use it as a handwheel, I only do it with my hand under the chuck at 6 o'clock (underneath), so that my fingers cannot be pulled into any holes. Putting your hand on the top is a really bad idea in any situation. BTW- because my handwheel is so close to the motor on my Nova, I have been pinched between the handwheel and the motor using it to slow the lathe down. I mostly use the handwheel to thread on the chuck and/or index.
If you are going to do it, make sure you think it through before sticking you hand up there.
Steve
P.S. I interpretted the original post as "fingers to close to the jaws while sanding"- yeah, that hurts like h&ll since it's the equivalent of a 4# rotation hammer whack. I rarely sand on the lathe...
Re: Fear the chuck
My Fear.....
is not so much getting a finger in the hole with the lathe running at speed in the forward direction, but casually sticking one in there with the lathe slowing down with a heavy blank in the chuck. I agree that it would be hard to do at 1000 rpm and or with the holes going away in reverse. Try visualizing 5 or 10 rpms with the holes coming at you. That's where that muscle speed thing would work against you. The reaction time would be so slow that it could be awful. I don't clearly remember the circumstances, but I had one nip me and it was a real pucker moment.
Re: Fear the chuck
ebd
no fear BUT huge respect & caution
ebd
I designed and had some Cole Jaw extenders made for me by my next door neighbor machinest. They allow me to reverse a bowl 16+ inches in diameter. They don't scare me, but I am very careful when using them.
