Unexplored Area?
Unexplored Area?
Unexplored Area?
charlie belden
I saw this while looking into Trompe L'oel (there seem to be several spellings) and it's an idea Salvador Dali often used - an image hidden within an image.
Rather than using piercing to allow both the outside AND some of the inside of a piece to be seen, or to give the piece a sense of movement as J. Paul Fennel's pieces have - this idea uses part of the outside surface and part of the inside surface to create a potentially interesting incongruity. Looking just at the outline of the opening in the outside surface or just at the outline of the opening in the inside surface you don't "get the picture". But when you "see" them combined and ignore This In Front, That In Back - the effect is interesting.
Yet another area to play in - or not.
Give YOU any ideas?
Re: Unexplored Area?
Brian George
Hey! That IS another great idea for the grist mill...
Thanks...
Don Pencil
Give YOU any ideas? Yes.......
Don Pencil
I have got to quit smokin' the mushrooms. :O
Re: Give YOU any ideas? Yes.......
charlie belden
Does smoking them give them a barbecue taste?
Would a regular smoker used for fish and meats work with mushrooms?
What woods have you found to produce the best "smokey" flavor?
Do you do any special prepping of the mushrooms?
Do you monitor the Moisture Content of the mushrooms in order
to tell when they're ready to use?
Don Pencil
Don Pencil
D. None of the above.
The "Candy Man" does all of that for me. :O
