Re: About those gouges...
Greg Haugen
There's no flat, nothing to interrupt the flow of the form from the rim back around to the rim. The round bottom bowls have a nice "rock" to them that can be very captivating.
For this bowl I used three gouges. I'll list them in American sizes.
5/8" with a swept back grind at 40 degrees (top).
1/2" with a swept back grind of 50 degrees (middle).
1/2" stubby traditional grind with a shorten 60 degree bevel (bottom).
If this bowl was deeper I'd switch the 5/8" and the 1/2" swept back gouge angles. But since it was only 4 1/2" deep the 1/2" gouge worked out nicely.
All of the gouges are hand ground, not a "jigged". That's just my preference so I can easily change the angle to anything I'd like without a lot of hassle. All have a double or relief bevel to lessen the bevel contact. It also only takes a couple of seconds to "refresh the edge" or to change the angle without changing a fully ground bevel to a different angle. The 60 degree grind has less than an 1/8" inch bevel, closer to a 1/16". The other two are a little more than an 1/8" at the nose.
The steeper/sharper the grind, the higher on the form it's used. I used the 40 degree grind from the rim to the largest diameter, a little below half way. Then the 50 degree grind until a little before the bottom. Then the 60 degree (Depending on the bowl shape, this grind can vary from 60 to about 80 degrees) for the bottom. The point is to keep the bevel on the wood. As the angle that the gouge needs to be "presented" to the wood, the gouge angle needs to compensate for it. IF a bowl has a very open form one or two gouges can cut all of it appropriately. If it has a deep and narrow form or a closed form, the angles the gouge can be presented to the wood are limited so the angle changes on the gouge.
